I’m trying to run DIGITS in a container on Ubuntu 16.04. I’ve done the usual steps - removed / blacklisted the nouveau display drivers etc, install latest drivers from the site. I’m still facing the dreaded error #35 though. Here are the versions that I’m using:
lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
nvidia-smi
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 Quadro 2000 Off | 00000000:03:00.0 Off | N/A |
| 30% 53C P0 N/A / N/A | 0MiB / 963MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
docker images
REPOSITORY TAG IMAGE ID CREATED
nvidia/digits latest fb4bfabb5acd 4 weeks ago
From what I understand, the only pre-requisite that the digits image has are the correct display drivers present. No cuda runtime / etc should be needed.
Any help would be appreciated.
