I’m developing on the Jetson TX2 running Jetpack 4.3 with a host system running Ubuntu 18.04 LTS. I’ve been going through the Two Days to a Demo tutorial, but I’ve gotten stuck on importing the first classification dataset.
After downloading the image recognition dataset and generating the directory structure and links, I get the “Folder does not exist” error when I try to import the classification dataset. In addition, the DIGITS client shows a different root directory structure than exists on either the target or host system?
I have downloaded the dataset to my host system and not the Jetson.
I tried different combinations of lukeyeager’s suggestion, but none of them worked.
My working hypothesis is that the DIGITS client is accessing some filesystem that is not my host system. The web interface shows a different root directory structure than my host system root directory, as shown in the attached images.
I am running the DIGITS server on my host system. However, the directory that is displayed in the DIGITS interface is not the directory of my host system.
We setup a host and confirm that DIGITs can load the host folder without issue.
Please noticed that DIGITs will open the host folder that has digits-devserver running on.
It won’t be the device that use for opening the DIGITs website.
If this issue goes on, could you restart or reinstall DIGITs to see if helps?
