• Hardware (T4/V100/Xavier/Nano/etc)
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Are bboxes turned on by default in Dino inference? I just trained an object detection dataset with a map50 evaluation of 31.4. However, when I run inference the output images do not have bboxes. Corresponding label files are created with bboxe coordinates. Is there a spec configuration I am missing?
Thanks, Morgan. Yes, I have scoured the documentation multiple times. Although I assumed boxes are turned on by default, I didn’t see anything to confirm that. I have set colors for all my classes, but I have not changed the conf_threshold which is set at .50. So you are suggesting that if I lower the threshold this might correct the problem?
In followup to your response, I adjusted the conf_threshold to .1 but I am still not getting bboxes. I suspect the issue is a simple solution. I have attached the following spec files to help troubleshoot:
train.yaml
evaluate.yaml
infer.yaml
inference.log
(upload would not allow yaml files so I changed extensions to txt
Morgan, I ran the dino inference inside the container and it ran without error. I have attached the file, inference.log showing a log of the process. Neither were there bboxes in the images produced from the exercise. I’m assuming the intent was to use any errors from running the inference to make modifications in the pl_dino_model.py or post_process.py files.
Without errors I’m at a loss to make any modifications. I do have a question, though. I noticed the post_process.py file established some METAINFO at the outset of the file which set a tuple of classes and a palette listing tuples of color. Is this a default should the colors not be mapped in the infer.yaml file? Does a color map in the infer.yaml file override this METAINFO? I could see this as a potential hindrance to having bboxes if there is a conflict between the two.
Morgan, I want to update this thread to report that I discovered the issue with the bounding boxes. I didn’t realize that a setting for the number of epochs was limiting the evaluation and inference to only half of the epochs I had trained. Once I corrected that, the bboxes began to appear, though I had to reduce the threshold to .3.
Once I had bboxes I had another issue. All labels were incorrect. Based on the documentation, I had listed my classes in reverse alphabetical order. Once I reverted back to a proper alphabetical order, the labels were all correct.
Thanks for your help, and this topic can be closed.
