Does Mellanox support DirectGMA?
DirectGMA is AMD’s PCIe peer-to-peer mechanism which is similar to Nvidia’s GPUDirect.
The one reference I could find was in a Mellanox slide presentation by Todd Wilde entitled "Paving The Road to Exascale Computing http://docplayer.net/22559934-Paving-the-road-to-exascale-computing-hpc-technology-update.html ":
“AMD DirectGMA P2P: Peer-to-Peer GPU-to-HCA data path under development”
Otherwise there is seemingly no mention of DirectGMA support.
Excellent suggestion, thank you. That does indeed look like the way to go.
idos
March 8, 2017, 11:34am
#3
I’m not a big expert on this, but I know the way to go today is to work with the ROCm driver, which supports Peer to Peer GPU VIA RDMA and has a peer plugin.
It’s not exactly DirectGMA (which never worked well beyond SD-I/O functionality).
See more details in - ROCm, a New Era in GPU Computing https://rocm.github.io/ , https://github.com/RadeonOpenCompute/ROCnRDMA https://github.com/RadeonOpenCompute/ROCnRDMA and https://rocm.github.io/ROCmRadeonProcompare.html https://rocm.github.io/ROCmRadeonProcompare.html
Hope it helps.
