Disable boot from the network
Hi all
We have found that the system sometimes boot from the network, causing boot failures. How can we disable boot from the network?
We use jp6.1 and uefi-202409.1
Hi 2639376969,
Are you using the devkit or custom board for Orin Nano?
You can remove those un-used boot device from UEFI manually.
Or you can refer to UEFI Adaptation — NVIDIA Jetson Linux Developer Guide 1 documentation to configure it in L4TConfiguration.dts before flash.
Hi KevinFFF
we using custom board,
Are you saying to remove the files here?
nvidia-uefi\edk2-nvidia\Silicon\NVIDIA\Tegra\DeviceTree
Please just modify this dts.
Hi KevinFFF
But it seems that there is no configuration to boot from the network here
Please remove ufs and check again.
Hi KevinFFF
I removed ufs, but it still boot from the network
Jetson System firmware version 202409.1-975fafc6-dirty date 2024-12-24T14:40:56+
08:00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
Start HTTP Boot over IPv6.
Could you try to remove the following line in NVIDIA.fvmain.fdf.inc?
- INF NetworkPkg/HttpBootDxe/HttpBootDxe.inf
and the following line in NVIDIA.common.dsc.inc?
- NetworkPkg/HttpBootDxe/HttpBootDxe.inf
