Disable debug printouts and get access to /dev/ttyS0
How to disable debug printouts to /dev/ttyS0 device and work with /dev/ttyS0:
  1. open file “Linux_for_Tegra/source/public/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-porg-p3448-common.dtsi”.
  2. Comment string “console-port;” in section “serial@70006000”. Example:
	serial@70006000 { /* UART-A : UART1: Debug */
		compatible = "nvidia,tegra210-uart", "nvidia,tegra114-hsuart", "nvidia,tegra20-uart";
		/* console-port; */
		sqa-automation-port;
		/delete-property/ resets;
		/delete-property/ reset-names;
		status = "okay";
  1. Compile the device tree.
  2. Flash the device tree to the Jetson Nano device.
  3. In Jetson Nano box open file “/boot/extlinux/extlinux.conf”.
  4. Delete string APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1.
  5. Insert string APPEND tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
  6. Save file and reboot the Jetson Nano box.
After that actions /dev/ttyS0 works well.
Thanks for your sharing about the steps to disable debug messages and use it as normal UART on Jetson Nano.
You are welcome!
