Disable EEPROM in dtb
I am using Antmicro board, which is, as I understand, based on Xavier NX devkit.
I have problem understanding what and how to recompile after disabling EEPROM (https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html#modifying-the-eeprom) on Jetpack 36.4? Do I need to recompile dtb? Do I need to recompile all kernel? Can I use just dtc from Linux_for_Tegra/kernel? Which dts/dtsi to recompile, only bootloader/tegra234-mb2-bct-common.dtsi? Where to put compiled dtb?
Can I still use p3509-a02-p3767-0000.conf for flashing OrinNX to test it on Xavier NX devkit?
Best regards,
Matevz
You don’t need to compile to decompile anything here. The mb2 dtsi file will be handled by the flash tool.
Also, it is not part of kernel dtb thing. DTB is just a format. It does not mean a DTB must be something related to kernel.
Also, there is no gurantee that p3509-a02 config can work for your board. As you said, this is a custom board. No matter what thing that is, it is not a NV devkit.
You should check with the vendor how to use it, but not “as I understand, it is based on XNX devkit”. What if your understanding is wrong here?
Yes, I agree and understand. I am first trying to make Orin NX with R36.4 work first in XNX devkit and NVMe memory, but I have some problems.
I use this command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 p3509-a02-p3767-0000 internal
But flashing fails with the following error:
[0047.907] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0047.912] I> t234-A01-1-Silicon (0x12347) Prod
[0047.916] I> Boot-mode : Coldboot
[0047.919] I> Entry timestamp: 0x00000000
[0047.923] I> last_boot_error: 0x0
[0047.926] I> BR-BCT: preprod_dev_sign: 0
[0047.930] I> rst_source: 0xb, rst_level: 0x1
[0047.934] I> Task: SE error check
[0047.937] I> Task: Bootchain select WAR set
[0047.941] I> Task: Enable SLCG
[0047.944] I> Task: CRC check
[0047.947] I> Task: Initialize MB2 params
[0047.951] I> MB2-params @ 0x40060000
[0047.955] I> Task: Crypto init
[0047.958] I> Task: Perform MB1 KAT tests
[0047.962] I> Task: NVRNG health check
[0047.965] I> NVRNG: Health check success
[0047.969] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0047.975] I> Task: Enabling and initialization of Bandwidth limiter
[0047.981] I> No request to configure MBWT settings for any PC!
[0047.987] I> Task: Secure debug controls
[0047.991] I> Task: strap war set
[0047.994] I> Task: Initialize SOC Therm
[0047.997] I> Task: Program NV master stream id
[0048.002] I> Task: Verify boot mode
[0048.007] I> Task: Alias fuses
[0048.011] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0048.018] I> Task: Print SKU type
[0048.021] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0048.027] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0048.031] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0048.035] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0048.039] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0048.044] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0048.048] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0048.053] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0048.057] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0048.061] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0048.065] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0048.070] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0048.074] I> FUSE_SKU_INFO_0 = 0xd3
[0048.077] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0048.081] I> FUSE_PACKAGE_INFO_0 = 0x2
[0048.085] I> SKU: Prod
[0048.087] I> Task: Boost clocks
[0048.090] I> Initializing NAFLL for BPMP_CPU_NIC.
[0048.095] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0048.100] I> BPMP NAFLL lock success.
[0048.104] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0048.109] I> Initializing PLLC2 for AXI_CBB.
[0048.113] I> AXI_CBB : src = 35, divisor = 0
[0048.117] I> Task: Voltage monitor
[0048.120] I> VMON: Vmon re-calibration and fine tuning done
[0048.126] I> Task: UPHY init
[0048.130] I> HSIO UPHY init done
[0048.133] W> Skipping GBE UPHY config
[0048.137] I> Task: Boot device init
[0048.140] I> Boot_device: RCM
[0048.143] I> USB configuration success
[0048.147] I> Task: TSC init
[0048.150] I> Task: Load membct
[0048.153] I> RAM_CODE 0x4000411
[0048.156] I> Loading MEMBCT
[0048.159] I> Slot: 0
[0048.161] I> Binary[0] block-0 (partition size: 0x40000)
[0048.166] I> Binary name: MEM-BCT-0
[0048.169] I> Size of crypto header is 8192
[0048.173] I> Size of crypto header is 8192
[0048.177] I> BCH of MEM-BCT-0 read from storage
[0048.182] I> BCH address is : 0x40050000
[0048.186] I> MEM-BCT-0 header integrity check is success
[0048.191] I> Binary magic in BCH component 0 is MEM0
[0048.195] I> component binary type is 0
[0048.201] I> MEM-BCT-0 binary is read from storage
[0048.206] I> MEM-BCT-0 binary integrity check is success
[0048.211] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0048.218] I> RAM_CODE 0x4000411
[0048.223] I> RAM_CODE 0x4000411
[0048.227] I> Task: Load Page retirement list
[0048.231] I> Task: SDRAM params override
[0048.235] I> Task: Save mem-bct info
[0048.238] I> Task: Carveout allocate
[0048.242] I> Update CCPLEX IST carveout from MB1-BCT
[0048.246] I> ECC region[0]: Start:0x0, End:0x0
[0048.251] I> ECC region[1]: Start:0x0, End:0x0
[0048.255] I> ECC region[2]: Start:0x0, End:0x0
[0048.259] I> ECC region[3]: Start:0x0, End:0x0
[0048.264] I> ECC region[4]: Start:0x0, End:0x0
[0048.268] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0048.274] I> Non-ECC region[1]: Start:0x0, End:0x0
[0048.278] I> Non-ECC region[2]: Start:0x0, End:0x0
[0048.283] I> Non-ECC region[3]: Start:0x0, End:0x0
[0048.288] I> Non-ECC region[4]: Start:0x0, End:0x0
[0048.298] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0048.305] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0048.312] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0048.319] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0048.327] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0048.334] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0048.341] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0048.348] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0048.355] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0048.362] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0048.369] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0048.376] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0048.383] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0048.390] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0048.396] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0048.403] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0048.410] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0048.417] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0048.424] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0048.431] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0048.438] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0048.445] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0048.452] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0048.459] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0048.466] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0048.473] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0048.479] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0048.486] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0048.494] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0048.501] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0048.507] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0048.514] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0048.521] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0048.528] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0048.534] I> Task: Thermal check
[0048.538] I> Using min_chip_limit as min_tmon_limit
[0048.542] I> Using max_chip_limit as max_tmon_limit
[0048.547] I> BCT max_tmon_limit = 105
[0048.550] I> BCT min_tmon_limit = -28
[0048.554] I> BCT max_tmon_limit = 105
[0048.557] I> BCT min_tmon_limit = -28
[0048.561] I> SKU specific max_chip_limit = 105
[0048.565] I> SKU specific min_chip_limit = -28
[0048.570] I> BCT max_chip_limit = 105
[0048.573] I> BCT min_chip_limit = -28
[0048.576] I> enable_soctherm_polling = 0
[0048.580] I> max temp read = 54
[0048.583] I> min temp read = 52
[0048.586] I> Enabling thermtrip
[0048.589] I> Task: Update FSI SCR with thermal fuse data
[0048.594] I> Task: Enable WDT 5th expiry
[0048.598] I> Task: I2C register
[0048.601] I> Task: Set I2C bus freq
[0048.604] I> Task: Reset FSI
[0048.607] I> Task: Pinmux init
[0048.610] I> skipped mmio_addr = 0x9240008
[0048.614] I> skipped mmio_addr = 0x9240000
[0048.618] I> skipped mmio_addr = 0x9240010
[0048.622] I> skipped mmio_addr = 0x9240018
[0048.626] I> skipped mmio_addr = 0x9240020
[0048.630] I> skipped mmio_addr = 0x9240030
[0048.634] I> skipped mmio_addr = 0x9240028
[0048.638] I> skipped mmio_addr = 0x9240038
[0048.642] I> skipped mmio_addr = 0x9240040
[0048.646] I> skipped mmio_addr = 0x9240048
[0048.650] I> skipped mmio_addr = 0x9241000
[0048.654] I> skipped mmio_addr = 0x9241008
[0048.658] I> skipped mmio_addr = 0x9241010
[0048.662] I> skipped mmio_addr = 0x9241018
[0048.666] I> skipped mmio_addr = 0x9241020
[0048.670] I> skipped mmio_addr = 0x9241028
[0048.674] I> skipped mmio_addr = 0x9241030
[0048.677] I> skipped mmio_addr = 0x9241038
[0048.681] I> skipped mmio_addr = 0x9241040
[0048.685] I> skipped mmio_addr = 0x9242000
[0048.689] I> skipped mmio_addr = 0x9242008
[0048.693] I> Task: Prod config init
[0048.697] I> Task: Pad voltage init
[0048.700] I> Task: Prod init
[0048.703] I> Task: Program rst req config reg
[0048.707] I> Task: Common rail init
[0048.710] I> DONE: Thermal config
[0048.714] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0048.722] I> DONE: SOC rail config
[0048.726] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0048.733] I> DONE: MEMIO rail config
[0048.737] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0048.743] I> DONE: GPU rail info
[0048.746] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0048.752] I> DONE: CV rail info
[0048.755] I> Task: Mem clock src
[0048.758] I> Task: Misc. board config
[0048.762] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0048.768] I> Task: SDRAM init
[0048.771] I> MemoryType: 4 MemBctRevision: 2
[0048.778] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0048.785] I> MSS CAR: Init PLLM
[0048.788] I> MSS CAR: Init PLLHUB
[0048.793] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0048.804] I> SDRAM initialized!
[0048.807] I> SDRAM Size in Total 0x400000000
[0048.811] I> Task: Dram Ecc scrub
[0048.814] I> Task: DRAM alias check
[0048.821] I> Task: Program NSDRAM carveout
[0048.825] I> NSDRAM carveout encryption is enabled
[0048.830] I> Program NSDRAM carveout
[0048.833] I> Task: Register checker
[0048.837] I> Task: Enable clock-mon
[0048.841] I> FMON: Fmon re-programming done
[0048.845] I> Task: Mapper init
[0048.848] I> Task: SC7 Context Init
[0048.851] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0048.857] I> Task: CCPLEX IST init
[0048.860] I> Task: CPU WP0
[0048.863] I> Loading MCE
[0048.865] I> Slot: 0
[0048.867] I> Binary[8] block-134217728 (partition size: 0x80000)
[0048.873] I> Binary name: MCE
[0048.876] I> Size of crypto header is 8192
[0048.880] I> Size of crypto header is 8192
[0052.348] I> BCH of MCE read from storage
[0052.352] I> BCH address is : 0x4003e000
[0052.356] I> MCE header integrity check is success
[0052.361] I> Binary magic in BCH component 0 is MTSM
[0052.366] I> component binary type is 8
[0052.369] I> Size of crypto header is 8192
[0052.377] I> MCE binary is read from storage
[0052.381] I> MCE binary integrity check is success
[0052.386] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0052.392] I> Size of crypto header is 8192
[0052.396] I> Sending WP0 mailbox command to PSC
[0052.405] I> Task: XUSB Powergate
[0052.408] I> Skipping powergate XUSB.
[0052.412] I> Task: MB1 fixed firewalls
[0052.418] W> Firewall readback mismatch
[0052.423] I> Task: Load bpmp-fw
[0052.426] I> Slot: 0
[0052.428] I> Binary[15] block-251658240 (partition size: 0x180000)
[0052.434] I> Binary name: BPMP_FW
[0052.438] I> Size of crypto header is 8192
[0052.441] I> Size of crypto header is 8192
[0052.446] I> BCH of BPMP_FW read from storage
[0052.450] I> BCH address is : 0x807fe000
[0052.454] I> BPMP_FW header integrity check is success
[0052.459] I> Binary magic in BCH component 0 is BPMF
[0052.463] I> component binary type is 15
[0052.467] I> Size of crypto header is 8192
[0052.489] I> BPMP_FW binary is read from storage
[0052.495] I> BPMP_FW binary integrity check is success
[0052.500] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0052.507] I> Slot: 0
[0052.509] I> Binary[16] block-268435456 (partition size: 0x400000)
[0052.515] I> Binary name: BPMP_FW_DTB
[0052.518] I> Size of crypto header is 8192
[0052.522] I> Size of crypto header is 8192
[0052.526] I> BCH of BPMP_FW_DTB read from storage
[0052.531] I> BCH address is : 0x807fc000
[0052.535] I> BPMP_FW_DTB header integrity check is success
[0052.540] I> Binary magic in BCH component 0 is BPMD
[0052.545] I> component binary type is 16
[0052.549] I> Size of crypto header is 8192
[0052.559] I> BPMP_FW_DTB binary is read from storage
[0052.565] I> BPMP_FW_DTB binary integrity check is success
[0052.570] I> Binary BPMP_FW_DTB loaded successfully at 0x807a06b0 (0x5b940)
[0052.577] I> Task: BPMP fw ast config
[0052.581] I> Task: Load psc-fw
[0052.583] I> Slot: 0
[0052.585] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0052.591] I> Binary name: PSC_FW
[0052.595] I> Size of crypto header is 8192
[0052.598] I> Size of crypto header is 8192
[0052.603] I> BCH of PSC_FW read from storage
[0052.607] I> BCH address is : 0x80ffe000
[0052.610] I> PSC_FW header integrity check is success
[0052.615] I> Binary magic in BCH component 0 is PFWP
[0052.620] I> component binary type is 17
[0052.624] I> Size of crypto header is 8192
[0052.633] I> PSC_FW binary is read from storage
[0052.638] I> PSC_FW binary integrity check is success
[0052.643] I> Binary PSC_FW loaded successfully at 0x80fb4210 (0x49df0)
[0052.649] I> Task: Load nvdec-fw
[0052.653] I> Slot: 0
[0052.655] I> Binary[7] block-117440512 (partition size: 0x100000)
[0052.661] I> Binary name: NVDEC
[0052.664] I> Size of crypto header is 8192
[0052.667] I> Size of crypto header is 8192
[0052.672] I> BCH of NVDEC read from storage
[0052.676] I> BCH address is : 0x800fe000
[0052.679] I> NVDEC header integrity check is success
[0052.684] I> Binary magic in BCH component 0 is NDEC
[0052.689] I> component binary type is 7
[0052.693] I> Size of crypto header is 8192
[0052.702] I> NVDEC binary is read from storage
[0052.707] I> NVDEC binary integrity check is success
[0052.711] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0052.720] I> Task: Load tsec-fw
[0052.723] I> TSEC-FW load support not enabled
[0052.727] I> Task: GPIO interrupt map
[0052.731] I> Task: SC7 context save
[0052.735] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0052.741] I> Task: Load MB2/Applet/FSKP
[0052.744] I> Loading MB2
[0052.747] I> Slot: 0
[0052.749] I> Binary[6] block-100663296 (partition size: 0x80000)
[0052.755] I> Binary name: MB2
[0052.757] I> Size of crypto header is 8192
[0052.761] I> Size of crypto header is 8192
[0052.765] I> BCH of MB2 read from storage
[0052.769] I> BCH address is : 0x8007e000
[0052.773] I> MB2 header integrity check is success
[0052.778] I> Binary magic in BCH component 0 is MB2B
[0052.783] I> component binary type is 6
[0052.786] I> Size of crypto header is 8192
[0052.798] I> MB2 binary is read from storage
[0052.803] I> MB2 binary integrity check is success
[0052.807] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0052.814] I> Task: Map CCPLEX SHARED carveout
[0052.818] I> Task: Prepare MB2 params
[0052.822] I> Task: Dram ecc test
[0052.825] I> Task: Misc NV security settings
[0052.829] I> NVDEC sticky bits programming done
[0052.833] I> Successfully powergated NVDEC
[0052.837] I> Task: Disable/Reload WDT
[0052.841] I> Task: Program misc carveouts
[0052.845] I> Program IPC carveouts
[0052.848] I> Task: Disable SCPM/POD reset
[0052.852] I> SLCG Global override status := 0x0
[0052.856] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> Boot-mode : RCM BOOT
I> Emulation:
I> Entry timestamp: 0x0326efa1
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: Set blob address
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
Any idea what it could be? I was thinking at first, it is related to EEPROM as I am not sure if it is in XNX devkit, but disabling it results in the same error. I also have Hadron board, and there all works OK with their CTI BSP.
For Orin NX/Nano, it is tegra234-mb2-bct-misc-p3767-0000.dts.
This is not something you need to “memorize”. You could just read your flash log and it will tell you what file is flashed into the board.
