after reboot from the following command I can see:
root@localhost:/sys/class/gpio# cat /sys/kernel/debug/gpio
gpiochip2: GPIOs 240-247, parent: platform/max77620-gpio, max77620-gpio, can sleep:
gpio-246 ( |gpio_default ) out hi
gpio-247 ( |gpio_default ) out hi
gpiochip1: GPIOs 248-287, parent: platform/c2f0000.gpio, tegra-gpio-aon:
gpio-253 ( |pex-refclk-sel-low ) out lo
gpio-284 ( |power-key ) in hi
gpiochip0: GPIOs 288-511, parent: platform/2200000.gpio, tegra-gpio:
gpio-288 ( |vdd-1v8-sd ) out hi
gpio-289 ( |? ) out hi
gpio-291 ( |vdd-hdmi-5v0 ) out hi
gpio-336 ( |force-recovery ) in hi
gpio-339 ( |wifi-enable ) out hi
gpio-341 ( |eqos_phy_reset ) out hi
gpio-343 ( |cd ) in hi
gpio-346 ( |temp-alert ) in hi
gpio-378 ( |pcie_wake ) in hi
gpio-386 ( |hdmi2.0_hpd ) in lo
gpio-389 ( |vdd_sys_en ) out lo
gpio-390 ( |reset_gpio ) out hi
gpio-391 ( |bt_ext_wake ) out hi
gpio-392 ( |avdd-cam-2v8 ) out lo
gpio-480 ( |bt_host_wake ) in lo
gpio-489 ( |vdd-5v-sata ) out hi
gpio-490 ( |? ) out lo
Is there a way to let gpio-289 and gpio-391 to set to lo on boot up time ?
Those pins are occupied because some drivers register them and set it as high. But I am not sure which driver is gpio289…since that is a “?”.
Only those drivers are able to control the status of those gpio. Unless you remove those drivers.
Is there a way to findout which driver uses uses gpio289 ?
I already modify the device tree and the dmesg already showing:
dmesg | grep “pcie-reg”
[0.982773] GPIO line 490 (pcie-reg-enable) hogged as output/high
[0.982815] GPIO line 289 (pcie-reg-disable) hogged as output/low
but cat /sys/kernel/debug/gpio still gets:
I am not very sure what do you mean “I already modify the device tree and the dmesg already showing:”
Could you check the debug node before you modify the device tree? It should tell the correct name instead of “?”.
I change:
gpio@2200000 {
pcie-reg-enable {
gpio-hog;
gpios = <TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH>;
/TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW>;/
label = “pcie-3v3-reg”;
/, “pcie-12v-reg”;/
output-high;
status = “okay”;
pcie-reg-disable {
gpio-hog;
gpios = <TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW>;
label = "pcie-12v-reg-disable";
output-low;
status = "okay";
and it is still the same
Do you mean the result is always “?” before and after you modify the DT?
Let me check what is going on there.
It seems the “?” does not harm. Which file did you modify the GPIO status?
its in platform/t19x/galen/kernel-dts/common/tegra194-p2888-0000-a00.dtsi
gpio@2200000 {
pcie-reg-enable {
gpio-hog;
/*TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW>;*/
label = "pcie-3v3-reg";
/*, "pcie-12v-reg";*/
output-high;
status = "okay";
pcie-reg-disable {
gpio-hog;
output-low;
status = "okay";
So it is still “hi” after your modification?
yes its still showing “hi” despite I saw this in desmg:
I think the cause of this issue is due to the next tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) in that file(tegra194-p2888-0000-a00.dtsi).
nvidia,plat-gpios =
<&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH /* 3V3 /
&tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW / 12V /
/&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 4) GPIO_ACTIVE_HIGH / / I2C */
Which is PCIe controller.
It means this pin is occupied by the PCIe controller.
oh thanks, so I just need to comment it out like:
nvidia,plat-gpios =
/&tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW*/ /* 12V /
after commenting it out, it is still showing high.
gpio-289 ( |pcie-reg-disable ) out hi
although my setting is low:
pcie-reg-disable {
gpio-hog;
label = “pcie-12v-reg-disable”;
output-low;
status = “okay”;
Hi wenbin.leong,
There is one thing to check.
If you remove TEGRA194_MAIN_GPIO(A, 1) from both nvidia,plat-gpios and gpio@2200000, will you still see it in debug/gpio?
Hi
I change GPIO_ACTIVE_LOW to GPIO_ACTIVE_HIGH and now its showing “lo”
Hi
GPIO_ACTIVE_LOW may reverse the active status. In such case, 0 means high and 1 means low.
Thus when you set “output-low”, it would automatically set it to hi.
