Disable GPU memory chip
Is there any way to disable one of memory chip (Device memory) attached to my GPU?
i.e., there are 4 memory chips (8Gb each) on my GTX960. I want to remove 3 of them and use leave only one.
I feel like I would try to mod VBIOS, but hoping another workaround.
I don’t think this is possible. The GPU likely will not function without all memory equipped.
There is no power gating circuit that would turn off individual memory chips. Power savings could only be achieved by setting a lower memory clock (something that is often done by GPU miners to save power)
If you’d physically remove some memory chips, the GPU will likely not work anymore. There is a certain memory bus width that each GPU model requires to be equipped.
nVidia can fuse off parts of the chips it produces, also reducing memory bus width in the process. e.g. the same GPU die can become a Titan XP, a Geforce 1080Ti or a Geforce 1080. They differ in the total amount of memory (chip count) and memory bus width, yet these GPUs are made from the same silicon die.
GPU spreads data between memory controllers in 32-byte chunks (or a little more), so disabling some of them will have dramatic effect even if you will avoid checks :) it requires some internal changes to change the memory mapping, although there is possibility that it can be made at software level (i.e. by programming the memory controller)
