Disable nvgetty service in BSP
Hi How to disable nvigetty service running in Jetson Nano from source or in BSP? I know in running system we can disable using command
sudo systemctl stop nvgetty.service
sudo systemctl disable nvgetty.service
If I want to disable it from BSP or source is there any way? I get debug console messages on THS0/1 sometime.
Such service is just a text file in the system. You can search the name of it and remove it from the systemd directory.
