GPU
• DeepStream Version
7.0
• TensorRT Version
How can i disable this very annoying logging from nvvideoconvert?
> 2024-08-02T18:08:26+02:00 0:20:01.504490274 19 0x7f1e78251fa0 WARN nvvideoconvert gstnvvideoconvert.c:2083:gst_nvvideoconvert_fixate_caps:<nvvideoconvert_5> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
> 2024-08-02T18:08:26+02:00 0:20:01.504505583 19 0x7f1e78251fa0 WARN nvvideoconvert gstnvvideoconvert.c:2088:gst_nvvideoconvert_fixate_caps:<nvvideoconvert_5> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
> 2024-08-02T18:08:26+02:00 0:20:01.991006911 19 0x7f1e78251ef0 WARN nvvideoconvert gstnvvideoconvert.c:2083:gst_nvvideoconvert_fixate_caps:<nvvideoconvert_2> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
> 2024-08-02T18:08:26+02:00 0:20:01.991023322 19 0x7f1e78251ef0 WARN nvvideoconvert gstnvvideoconvert.c:2088:gst_nvvideoconvert_fixate_caps:<nvvideoconvert_2> gpu-id property is set based on SRC caps. Property config setting (if any)
Cheers,
/M
