I connected an external device via UART pins at the J41 40-pin connector on the jetson nano developer kit. As mentioned here [url]https://www.jetsonhacks.com/nvidia-jetson-nano-j41-header-pinout/[/url] this is UART2 and it is accessible via ttyTHS1. I can send/receive data to/from the external device via my own C application. But it doesn’t work stable. Now I saw that when I connect via a terminal program from pc, a login prompt appears on ttyTHS1.
Is there another UART wich is not used by the system internally and which can be used by own applications?
How can I disable console login via ttyTHS1 without modifiying kernel, device tree or boot options as mentioned here [url]Serial Console Setup/Parameters - Jetson Nano - NVIDIA Developer Forums? Is there a service which could just be stopped to achieve this?
Thanks a lot
Marc
