I have installed R28.2 on my TX2 board. The version of Gstreamer is 1.8.3 and the version of ubuntu is 16.04. I want to disable the desktop when rebooting. I have tried these two instructions:
$ sudo systemctl stop lightdm.service
$ sudo systemctl mask lightdm.service
But it doesn’t work when rebooting. What is the problem? Thank you very much.
Try this:
sudo systemctl disable lightdm.service
(reverse is just “enable” instead of “disable”)
If that fails, try this, but save a copy of any existing file prior to the change:
sudo echo "manual" > /etc/init/failsafe-x.override
sudo echo "manual" > /etc/init/lightdm.override
Thank you. It works for me:
sudo chmod -x /usr/sbin/lightdm
