A note before I start
I am a Japanese developer and my English is not strong. I wrote the original text in Japanese and used a generative AI to translate it into English, so the wording you see here is machine-assisted. The content is entirely mine and I stand behind it. Every number in this post is measured on my own boards.
I have three Jetson Orin Nano Super boards and I use them for a range of work. Any help would be much appreciated.
Summary
On Jetson Linux R36.4.3, NvBufSurfaceAllocate with disablePitchPadding = true returns a tight pitch (pitch == width for GRAY8). On Jetson Linux R39.2.1 the same call on the same board returns a pitch rounded up to a 256-byte boundary, and the flag makes no difference at all (true and false produce identical results).
The header documentation is unchanged between the two releases and still states that the pitch will be “width times bytes per pixel”.
Is this an intentional behavior change on R39.x, or a regression? If it is intentional, is there a supported way to obtain a tight-pitch, host-mappable NvBufSurface on R39.x?
Why this matters for us
We capture 8-bit Bayer frames at 227 fps from a Basler USB3 Vision camera. We allocate NVBUF_MEM_CUDA_PINNED surfaces with disablePitchPadding = true and hand the mapped host pointer straight to the Basler SDK’s IBufferFactory, so the camera writes directly into the surface with no cudaMemcpy2D. That zero-copy path depends on pitch == width, because the Basler SDK writes tightly packed rows. On R39.2.1 the pitch is 1536 for width 1440, so the direct-write path is no longer possible and we have to add a per-frame row-by-row copy.
Hardware
Both boards are the same model:
NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
Software
| Board A | Board B | |
/etc/nv_tegra_release |
R36 (release), REVISION: 4.3, GCID 38968081 | R39 (release), REVISION: 2.1, GCID 46758480 |
nvidia-l4t-multimedia-utils |
36.4.3-20250107174145 | 39.2.1-20260806224157 |
| DeepStream | 7.1.0-1 | 9.1.0-1 |
| TensorRT | 10.3.0.30-1+cuda12.5 | 10.16.2.10-1+cuda13.2 |
| Kernel | R36.4.3 stock | 6.8.12-1021-tegra |
libnvbufsurface.so.1.0.0 is provided by nvidia-l4t-multimedia-utils on both boards (verified with dpkg -S), so this is an L4T-level difference rather than a DeepStream one.
Reproducer
/* build: g++ -O0 -o probe_pitch probe_pitch.c \
* -I/opt/nvidia/deepstream/deepstream/sources/includes \
* -L/opt/nvidia/deepstream/deepstream/lib -lnvbufsurface \
* -Wl,-rpath,/opt/nvidia/deepstream/deepstream/lib
#include <nvbufsurface.h>
#include <stdio.h>
#include <string.h>
static void probe(NvBufSurfaceMemType mem, bool disable, unsigned w, unsigned h) {
NvBufSurfaceAllocateParams p;
memset(&p, 0, sizeof(p));
p.params.gpuId = 0;
p.params.width = w;
p.params.height = h;
p.params.isContiguous = true;
p.params.colorFormat = NVBUF_COLOR_FORMAT_GRAY8;
p.params.layout = NVBUF_LAYOUT_PITCH;
p.params.memType = mem;
p.disablePitchPadding = disable;
p.memtag = NvBufSurfaceTag_CAMERA;
NvBufSurface *s = NULL;
if (NvBufSurfaceAllocate(&s, 1, &p) != 0 || !s) { printf("alloc failed\n"); return; }
s->numFilled = 1;
printf("memType=%d disablePitchPadding=%-5s width=%4u -> pitch=%4u\n",
(int)mem, disable ? "true" : "false", w,
s->surfaceList[0].planeParams.pitch[0]);
NvBufSurfaceDestroy(s);
int main(void) {
const unsigned ws[] = {100, 1024, 1280, 1440, 1441, 1536, 1920};
for (unsigned i = 0; i < sizeof(ws)/sizeof(ws[0]); i++)
probe(NVBUF_MEM_CUDA_PINNED, true, ws[i], 1080);
return 0;
Results
NVBUF_MEM_CUDA_PINNED, NVBUF_COLOR_FORMAT_GRAY8, disablePitchPadding = true, height 1080:
| width | pitch on R36.4.3 | pitch on R39.2.1 |
| 100 | 100 | 256 |
| 1024 | 1024 | 1024 |
| 1280 | 1280 | 1280 |
| 1440 | 1440 | 1536 |
| 1441 | 1442 | 1536 |
| 1536 | 1536 | 1536 |
| 1920 | 1920 | 2048 |
On R36.4.3 the pitch equals the width, and for the odd width 1441 it is rounded to the next multiple of 2, which matches the header comment exactly. On R39.2.1 every pitch is rounded up to a multiple of 256 regardless of the flag.
The flag itself makes no difference on R39.2.1. Same width 1440, height 1080, GRAY8:
| memType | disablePitchPadding |
NVBUF_MEM_CUDA_PINNED |
true | 1440 | 1536 |
false | 1536 | 1536 |
NVBUF_MEM_CUDA_UNIFIED |
NVBUF_MEM_CUDA_DEVICE |
NVBUF_MEM_SYSTEM |
NVBUF_MEM_DEFAULT |
true | 1536 | 1536 |
NvBufSurfaceMap behavior is unchanged: it succeeds for CUDA_PINNED and CUDA_UNIFIED (with dataPtr == mappedAddr[0]), and fails for CUDA_DEVICE and SYSTEM, on both releases.
Documentation
The comment on the field is byte-for-byte identical in
/opt/nvidia/deepstream/deepstream-7.1/sources/includes/nvbufsurface.h (line 439) and
/opt/nvidia/deepstream/deepstream/sources/includes/nvbufsurface.h (line 489) on R39.2.1:
/** disable pitch padding allocation only applicable for cuda and system memory allocation
pitch would be width times bytes per pixel for the plane, for odd width it would be
multiple of 2, also note for some non standard video resolution cuda kernels may fail
due to unaligned pitch
bool disablePitchPadding;
On R39.2.1 the observed behavior does not match this description.
ABI note
sizeof(NvBufSurfaceAllocateParams) changed from 80 bytes on R36.4.3 to 120 bytes on R39.2.1, and offsetof(NvBufSurfaceAllocateParams, disablePitchPadding) moved from 44 to 80, because NvBufSurfaceCreateParams grew from 32 to 64 bytes. Our test program is compiled against the headers shipped on each board, so this is not a header/library mismatch on our side. I mention it only in case the field is being read at a stale offset somewhere inside the library.
Questions
- Is the 256-byte pitch alignment on R39.x intentional, with
disablePitchPaddingdeprecated or no longer honored? - If it is intentional, what is the supported way to allocate a host-mappable
NvBufSurfacewhosepitchequalswidth, so that an external SDK can write tightly packed rows directly into the surface? - If it is a regression, is there a release in which it will be restored, or a workaround for R39.x?
