I am trying to use the v4l2_nv_extensions
on a Nano w/ r32.6.1 to encode a VP8 stream but am having issues with headers. I was expecting to get an elementary stream however the first frame in the stream has an extra 44 bytes and subsequent frames have an extra 12 bytes which seems consistent with IVF headers getting added. I have tried calling VIDIOC_S_EXT_CTRLS
with V4L2_CID_MPEG_VIDEOENC_VPX_HEADERS_WITH_FRAME
and the value 0
but it doesn’t seem to have changed anything. I have also verified that data_offset
of the buffer from the capture plane is 0
. Am I missing something required to disable these headers? This application is a port of a gstreamer based application and I have not experienced the same header issue in the output from the nvv4l2vp8enc
element.
I also came across this older post which claims on the TX2 that VP9 should include the IVF headers by default but VP8 should be the raw stream, is this also the case on the Nano?
Thanks,
Kevin
