Disabling Nouveau drivers to enable use of NVIDIA drivers
I am running CentOS 7, and I am trying to figure out:
  1. What NVIDIA driver do I need?
  2. How to disable the Nouveau driver that is apparently blocking every attemptI make at installing the NVIDIA driver?
I hope the following helps:
$ lspci | grep -i vid
01:00.0 VGA compatible controller: NVIDIA Corporation GP104GLM [Quadro P3200 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Help.
Thanks,
Aaron
  1. Follow the wizard at: [url]Official Drivers | NVIDIA to select the latest driver for your GPU
  2. [url]Installation Guide Linux :: CUDA Toolkit Documentation
Note that you might want to study the guide listed in 2 first, before doing anything from 1.
The CUDA linux installers include a bundled driver, and the latest CUDA 10.1.243 includes a bundled driver that may work with your GPU. If not, the latest driver found in step 1 will work for your GPU, and will work with any CUDA version.
When I rebooted, my boot process hung with the message “Started Update UTMP about System Runlevel Changes.”
What do I do?
I don’t really know. You may need to disable secure boot. I don’t have a list of instructions to give you, so if you ask me “what do I do?” I probably won’t respond. However there are instructions all over the web on disabling secure boot. And it may not be a secure boot issue.
