Hi Current Setup is that way :
2 x SX1012
Port 1-4 are configured as hybrid and connected to nutanix servers. Port 5 is a breakout cable still connected to nutanix servers and set to hybrid. (All are 10GB)
Port 9 is set to hybrid and connected to a backup server (10GB)
Port 10 is connected to a juniper switch over 40GB
Port 11-12 is connected to the other mellanox switch using LACP (2 56GB set to hybrid)
As per Nutanix recommendations, it is recommended to disable spanning tree. As soon as I do that the servers lose connections to themselves and crashes. What would be the cause?
I have attached the pictures from the Spanning tree config of both switches. Notice how one is different even though the settings are the same.
