During boot, there is a ~2 minute delay while the Xavier NX looks for a WIFI module that doesn’t exist on our custom carrier board. To avoid this delay, we would like to remove the WLAN from boot.
Based on other forum posts, I’ve gathered the following:
- Disable
output-high
for wifi-enable
// tegra194-comms.dtsi
gpio@2200000 {
wifi-enable {
gpio-hog;
// output-high;
gpios = <TEGRA194_MAIN_GPIO(G, 3) 0>;
label = "wifi-enable";
status = "okay";
- Update status from
okay
todisabled
bcmdhd_pcie_wlan {
compatible = "android,bcmdhd_pcie_wlan";
wlan-pwr-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 3) 0>;
fw_path = "/vendor/firmware/fw_bcmdhd_4356.bin";
nv_path = "/vendor/firmware/nvram_4356.txt";
status = "disabled";
- Remove the following lines from tegra_defconfig
// tegra_defconfig
CONFIG_BCMDHD=m
CONFIG_BCMDHD_SDIO=y
CONFIG_BCMDHD_PCIE=y
CONFIG_BCM4354=y
CONFIG_BCMDHD_FW_PATH="/lib/firmware/brcm/fw_bcmdhd.bin"
CONFIG_BCMDHD_NVRAM_PATH="/lib/firmware/brcm/nvram.txt"
CONFIG_BCMDHD_HW_OOB=y
CONFIG_DHD_USE_SCHED_SCAN=y
CONFIG_BCMDHD_DISABLE_MCC=y
CONFIG_BCMDHD_PCIE_FW_PATH="/lib/firmware/brcm/fw_bcmdhd_4356.bin"
CONFIG_BCMDHD_PCIE_NVRAM_PATH="/lib/firmware/brcm/nvram_4356.txt"
CONFIG_BCMDHD_PCIE_ES4_NVRAM_PATH="/lib/firmware/brcm/nvram_murata_4359_b1_es4.txt"
Are these steps all that is necessary to disable WLAN?
