disappointing CUDA BLAS performance
[font=“Courier”][font=“Courier”]I have a simple program to compare the performance of cudablas with my own blas routines. One example is “cublasDsyr”. My test vector size is 512. My kernel is a simple unoptimized one, with 512 blocks of 512 threads (which means only N*(N+1)/2 of the threads will be active). But even with this kernel the timing for 1000 iteration is 60 ms, vs 81ms for “cublasDsyr”. With a little optimization (using 256 threads) my kernel takes 50 ms. I cannot believe that a naive algorithm like mine performs better than cublas. So what am I missing?
Thanks for any help.
main()
{</P> <P>int i = 1000;</P> <P>while(i--){
#if CUBLAS
	cublasDsyr('u',512, 1, Vec, 1, Matrix, 512);
#else
	MyDsyr<<<512, 512>>>(Vec, Matrix, 1);</P> <P>#endif
cudaThreadSynchronize();
}</P> <P>
__global__ void MyDsyr(const double *vec,  double *matrix, const double alfa)
__shared__ double vv;	//broadcast?</P> <P>//upper half calculation
int bx= blockIdx.x* N + threadIdx.x;</P> <P> if(threadIdx.x == 0){
  vv = vec[blockIdx.x]*alfa;
 __syncthreads();</P> <P> if(threadIdx.x <= blockIdx.x){
  matrix[ bx] += vv*vec[threadIdx.x];
 __syncthreads();
[/font][/font]
Sorry for the messed up code part in my original question. I still don’t know how to use this tool! I’ll just put the code as a part of this post until I figure it out.
main()
int i = 1000;
while(i–){
#if CUBLAS
cublasDsyr(‘u’,512, 1, Vec, 1, Matrix, 512);
#else
#endif
global void MyDsyr(const double *vec, double *matrix, const double alfa)
shared double vv; //broadcast?
__syncthreads();
__syncthreads();
