Disconnect problem during MACsec key update using ConnectX-7
Hello NVIDIA community,
When a new SA other than the one in use was created during ping communication using MACsec offload in Connext X-7, pinging did not pass.
Is there a way to create a new SA without the communication using the current SA breaking up?
[System Specifications]
・CPU: Intel Xeon Gold 6342, Memory: 256GB
・OS: Ubuntu 22.04, Kernel: 6.8.0-39-generic
・MLNX_OFED: 24.04-0.7.0.0
[Procedure]
1.MACsec encryption settings
Sender
/bin/bash
/opt/mellanox/iproute2/sbin/ip address flush enp23s0np0
/opt/mellanox/iproute2/sbin/ip address add 192.168.247.32/24 dev enp23s0np0
/opt/mellanox/iproute2/sbin/ip link set dev enp23s0np0 up
/opt/mellanox/iproute2/sbin/ip link add link enp23s0np0 macsec0 type macsec sci 1 encrypt on
/opt/mellanox/iproute2/sbin/ip macsec offload macsec0 mac
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 tx sa 0 pn 1 on key 00 dffafc8d7b9a43d5b9a3dfbbf6a30c16
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 rx sci 1 on
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 rx sci 1 sa 0 pn 1 on key 00 ead3664f508eb06c40ac7104cdae4ce5
/opt/mellanox/iproute2/sbin/ip address flush macsec0
/opt/mellanox/iproute2/sbin/ip address add 192.168.249.32/24 dev macsec0
/opt/mellanox/iproute2/sbin/ip link set dev macsec0 up
Receiver
#!/bin/bash
/opt/mellanox/iproute2/sbin/ip address add 192.168.247.33/24 dev enp23s0np0
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 tx sa 0 pn 1 on key 00 ead3664f508eb06c40ac7104cdae4ce5
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 rx sci 1 sa 0 pn 1 on key 00 dffafc8d7b9a43d5b9a3dfbbf6a30c16
/opt/mellanox/iproute2/sbin/ip address add 192.168.249.33/24 dev macsec0
  1. ping
#!/bin/bash
ping 192.168.249.32(example)
3.Create new SA
Sender
#!/bin/bash
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 tx sa 1 pn 1 on key 00 dffafc8d7b9a43d5b9a3dfbbf6a30c17
Receiver
#!/bin/bash
/opt/mellanox/iproute2/sbin/ip macsec add macsec0 rx sci 1 sa 1 pn 1 on key 00 dffafc8d7b9a43d5b9a3dfbbf6a30c17
  • No ping response at the time of new SA creation (TX side).
  • When the packet is captured, the PN is reset when the new SA is created in sender, and the SA (AN) is sent as it was.
4.SA Switching
#!/bin/bash
/opt/mellanox/iproute2/sbin/ip link set macsec0 type macsec encodingsa 1
  • After switching to the new SA, ping communication resumed.
  • When the packet is captured, the AN is also switched to the new SA settings and sent.
    (Without MACsec offload, the ping continued to communicate when running 3 above, and after switching 4, it communicated without any problems.)
Thank you in advance for your assistance!
No way do this.
Thank you for your reply.
Do you mean that MACsec key update without communication interruption is impossible?
