Dear NVIDIA,
We want to add a battery and charging solution to the Jetson AGX Orin development board. Can I incorporate the battery and charging solution into the Jetson AGX Orin development board using a block diagram? Could you help us confirm its feasibility? Thank you.
2025-04-17T16:00:00Z
Using battery and charging solution should be feasible as many applications like drones, robots are battery powered. However, we recommend you work closely with your battery and power solution provider to optimize the battery charging solution which meets your intended use case and needs. Keep in mind not to exceed the Vin range of the Jetson module in any circumstances. 22V is outside the normal operating range of the Jetson module.
Refer to Jetson AGX Orin Developer Kit Carrier Board Specification
