After applying the methods suggested in that thread, the frequency of firmware crashes has decreased significantly; however, some units still experience the same issue. My questions are:
What is the specific root cause of this problem? Is the PCIe link entering a low-power state?
Are there any specific requirements or compatibility considerations regarding the Wi-Fi access point (AP) to which the network adapter connects?
Provided below is the kernel log from a unit where this issue persists:
We are using JP 5.1.4—admittedly an older version—but due to considerations regarding internal batch iteration, we have not yet upgraded to the latest Jetpack.
If not already done, some of following may be useful:
# Have you tried a different firmware version?
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
# Is firmware 59 the highest supported by your driver.
(modinfo iwlwifi
modinfo iwlmvm
ethtool -i wlan0
lspci -vv -s 0001:01:00.0) |tee driver.txt
# Have you tried this utility? On this webpage search for `System Support Utility` and review that post.
It presents some troubleshooting steps. https://community.intel.com/t/ax210-crash-issue/119033
https://wireless.docs.kernel.org/en/latest/en/users/drivers/iwlwifi/debugging.html
Title: "How to provide information to debug the firmware?"
https://wireless.docs.kernel.org/en/latest/en/users/drivers/iwlwifi/debugging.html#firmware-debugging
The first crash occurs around 330–335 seconds after boot, multiple times in your log.
# Check the tracepoints your kernel supports:
sudo trace-cmd list -e | grep -E \
'^(iwlwifi|iwlwifi_msg|iwlwifi_data|mac80211|cfg80211|workqueue|power|timer):'
# As soon as you can after power on Orin, run:
sleep 240
sudo trace-cmd record -o /tmp/ax200-trace.dat -b 16384 -e iwlwifi \
-e iwlwifi_msg -e mac80211 -e cfg80211 \
sleep 240
