i change the environment using your RS32.7.1
i replace the nvidia dtb with our dtb in order to find the nvme device .
and the debug shows following
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0096.741] I> Welcome to TBoot-CPU Recovery
��fmon_post initialized
��[0096.742] I> Heap: [0xa4000000 ... 0xaa000000
[0096.742] I> gpio framework initialized
[0096.754] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
��[0096.765] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0096.769] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0096.846] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0096.852] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0096.855] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0096.861] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0096.870] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0096.878] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
��emc_debugfs initialized
dvs_debugfs initialized
��[0096.883] W> tegrabl_tca9539_init: failed to fetch phandle from dt��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0096.944] I> fixed regulator driver initialized
[0096.959] I> CPU: Nvidia Carmel
[0096.959] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0096.959] I> chip revision : A02P
[0096.960] I> Recovery boot_type: 1
[0096.960] I> ########## Fixed storage boot ##########
[0096.963] I> Loading kernel from blob
[0096.967] I> Found imgtype:37 in blob @ idx:10, offset:6156616, size: 49653760
[0096.988] I> Load address: 0xa4010000
[0096.989] I> Checking boot.img header magic ... [0096.989] I> [OK]
[0096.989] I> Loading kernel-dtb from blob
[0096.989] I> Found imgtype:38 in blob @ idx:11, offset:55810376, size: 299136
[0096.994] I> Load address: 0x90000000
[0096.998] I> Kernel hdr @0xa4010000
[0097.001] I> Kernel dtb @0x90000000
[0097.004] I> decompressor handler not found
[0097.008] I> Copying kernel image (34484232 bytes) from 0xa4010800 to 0x80080000 ... [0097.022] I> Done
[0097.023] I> Move ramdisk (len: 15163920) from 0xa60f4000 to 0x91000000
[0097.029] I> Updated bpmp info to DTB
[0097.031] I> Ramdisk: Base: 0x91000000; Size: 0xe76210
[0097.033] I> Updated initrd info to DTB
[0097.036] W> WARN: Fail to override "console=none" in commandline
[0097.042] I> Kernel type = Normal
[0097.046] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0097.103] I> Updated bootarg info to DTB
[0097.110] E> failed to read label property for node 233716: 13
[0097.114] E> failed to read reg property for node 233804: 13
[0097.119] E> failed to read label property for node 233856: 13
[0097.125] E> failed to read label property for node 233924: 13
[0097.130] E> failed to read label property for node 233960: 13
[0097.136] E> failed to read label property for node 233996: 13
[0097.142] E> failed to read reg property for node 234064: 13
[0097.147] E> failed to read label property for node 234116: 13
[0097.155] I> Find /i2c@3160000's alias i2c0
[0097.156] I> Reading eeprom i2c=0 address=0x50
[0097.185] I> Device at /i2c@3160000:0x50
[0097.186] I> Reading eeprom i2c=0 address=0x56
[0097.186] E> I2C: slave not found in slaves.
[0097.187] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0097.188] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.188] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0097.195] E> eeprom: Failed to read I2C slave device
[0097.200] I> Eeprom read failed 0x3526070d
[0097.206] I> Find /i2c@3180000's alias i2c2
[0097.208] I> Reading eeprom i2c=2 address=0x54
[0097.214] E> I2C: slave not found in slaves.
[0097.217] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0097.225] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.230] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0097.240] E> eeprom: Failed to read I2C slave device
[0097.244] I> Eeprom read failed 0x3526070d
[0097.248] I> Reading eeprom i2c=2 address=0x57
[0097.253] E> I2C: slave not found in slaves.
[0097.257] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0097.265] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.270] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0097.280] E> eeprom: Failed to read I2C slave device
[0097.284] I> Eeprom read failed 0x3526070d
[0097.288] I> Reading eeprom i2c=2 address=0x52
[0097.293] E> I2C: slave not found in slaves.
[0097.297] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0097.305] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.310] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0097.320] E> eeprom: Failed to read I2C slave device
[0097.325] I> Eeprom read failed 0x3526070d
[0097.330] I> Find /i2c@c240000's alias i2c1
[0097.333] I> Reading eeprom i2c=1 address=0x52
[0097.338] E> I2C: slave not found in slaves.
[0097.341] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0097.349] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.354] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0097.364] E> eeprom: Retry to read I2C slave device.
[0097.369] E> I2C: slave not found in slaves.
[0097.373] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0097.381] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.386] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0097.396] E> eeprom: Failed to read I2C slave device
[0097.401] I> Eeprom read failed 0x3526070d
[0097.404] I> Reading eeprom i2c=1 address=0x50
[0097.409] E> I2C: slave not found in slaves.
[0097.413] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0097.421] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.426] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0097.436] E> eeprom: Retry to read I2C slave device.
[0097.441] E> I2C: slave not found in slaves.
[0097.445] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0097.453] E> I2C_DEV: Failed to send register address 0x00000000.
[0097.458] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0097.468] E> eeprom: Failed to read I2C slave device
[0097.472] I> Eeprom read failed 0x3526070d
[0097.476] W> MAC addr invalid!
[0097.479] E> Failed to get WIFI MAC address
[0097.483] W> MAC addr invalid!
[0097.486] E> Failed to get Bluetooth MAC address
[0097.491] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:2f:fb:2d
[0097.498] E> Found no plugin manager ids in source DT
[0097.502] W> Add plugin manager ids from board info
[0097.506] W> "plugin-manager" doesn't exist, creating
[0097.511] W> "ids" doesn't exist, creating
[0097.515] W> "connection" doesn't exist, creating
[0097.520] W> "configs" doesn't exist, creating
[0097.524] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0097.529] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0097.540] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0097.547] W> "i2c@3160000" doesn't exist, creating
[0097.552] W> "module@0x50" doesn't exist, creating
[0097.559] I> Adding plugin-manager/cvm
[0097.560] W> "chip-id" doesn't exist, creating
[0097.564] I> Adding plugin-manager/chip-id/A02P
[0097.569] W> "odm-data" doesn't exist, creating
[0097.573] I> Adding /chosen/plugin-manager/odm-data
[0097.582] W> "memory" doesn't exist, creating
[0097.584] I> [0] START: 0x80000000, END: 0xe8b00000
[0097.587] I> dram_block larger than 80000000
[0097.591] I> [1] START: 0x100000000, END: 0x880000000
[0097.596] I> added [base:0x80000000, size:0x68a00000] to /memory
[0097.602] I> added [base:0x100000000, size:0x780000000] to /memory
[0097.609] I> Updated memory info to DTB
[0097.612] W> "reset" doesn't exist, creating
[0097.616] I> Adding ecid(00000001647dd5011000000017fe81c0) to DT
[0097.622] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0097.626] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0097.631] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0097.635] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0097.640] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0097.645] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0097.650] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0097.654] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0097.662] W> "misc-data" doesn't exist, creating
[0097.664] I> Boot-device: eMMC
[0097.666] I> Add boot-sdmmc to plugin-manager/misc-data
[0097.672] I> Add storage-sdmmc to plugin-manager/misc-data
[0097.677] W> Unknown storage device
[0097.682] I> Add serial number:1420121080127 as DT property
[0097.688] I> Plugin-manager override starting
[0097.691] W> Failed to find /plugin-manager in DT
[0097.694] I> tegrabl_load_kernel_and_dtb: Done
[0097.699] I> Filling _next_stage_param: ep: 0x80080000, dtb: 0x90000000
[0097.705] I> TBoot-CPU Recovery done
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5403-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d291202
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 68a00000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvids
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8162784
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifn
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29948(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 32478180K/33169408K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 625692K reserved,)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000008] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008684] Console: colour dummy device 80x25
[ 0.014970] console [tty0] enabled
[ 0.015857] kmemleak: Kernel memory leak detector disabled
[ 0.021301] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.031522] pid_max: default: 32768 minimum: 301
[ 0.037590] Security Framework initialized
[ 0.040753] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.047235] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.056814] ftrace: allocating 47098 entries in 184 pages
[ 0.595230] sched-energy: Sched-energy-costs installed from DT
[ 0.595548] ASID allocator initialised with 65536 entries
[ 0.633316] tegra-id: chipid=21917.
[ 0.633433] tegra-id: opt_subrevision=1.
[ 0.633544] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.633696] DTS File Name: /home/sunxuehu/work/geac_repo_manifests_jp4.6.1_545s_nx_r2.0/code/source/kernel_src/kernel/kernel-4.9/arch/arm6i
[ 0.634191] DTB Build time: Apr 20 2022 13:14:34
[ 0.687250] CPU1: Booted secondary processor [4e0f0040]
[ 0.719265] CPU2: Booted secondary processor [4e0f0040]
[ 0.751389] CPU3: Booted secondary processor [4e0f0040]
[ 0.783809] CPU4: Booted secondary processor [4e0f0040]
[ 0.815952] CPU5: Booted secondary processor [4e0f0040]
[ 0.848507] CPU6: Booted secondary processor [4e0f0040]
[ 0.880354] CPU7: Booted secondary processor [4e0f0040]
[ 0.880661] Brought up 8 CPUs
[ 0.881691] SMP: Total of 8 processors activated.
[ 0.881804] CPU features: detected feature: Privileged Access Never
[ 0.881940] CPU features: detected feature: LSE atomic instructions
[ 0.882112] CPU features: detected feature: User Access Override
[ 0.882245] CPU features: detected feature: 32-bit EL0 Support
[ 0.884982] CPU: All CPU(s) started at EL2
[ 0.885178] alternatives: patching kernel code
[ 0.896259] devtmpfs: initialized
[ 0.970284] Initilizing CustomIPI irq domain
[ 0.970695] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.970978] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.974187] pinctrl core: initialized pinctrl subsystem
[ 0.974554] OS set in device tree is not L4T.
[ 0.975071] regulator-dummy: no parameters
[ 0.975466] Initializing plugin-manager
[ 0.975658] Plugin module not found
[ 0.975806] Plugin-manager not available
[ 0.977703] NET: Registered protocol family 16
[ 0.986159] pstore: using zlib compression
[ 0.987283] console [pstore-1] enabled
[ 0.987402] pstore: Registered ramoops as persistent store backend
[ 0.987562] ramoops: attached 0x200000@0xe8800000, ecc: 0/0
[ 1.007186] cpuidle: using governor menu
[ 1.009301] bpmp: waiting for handshake
[ 1.009453] bpmp: handshake completed
[ 1.009600] bpmp: synchronizing channels
[ 1.009719] bpmp: channels synchronized
[ 1.009861] bpmp: mail init ok
[ 1.014759] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 1.015247] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 1.015456] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 1.015595] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 1.015775] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 1.015926] t19x-arm-smmu 12000000.iommu: nested translation
[ 1.016084] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 1.016508] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 1.027527] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 1.034483] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 1.041215] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 1.054161] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 1.055825] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.066752] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 1.073709] tegra_aon_clk_init: ok
[ 1.074255] Registering BPMP clocks...
[ 1.078377] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 1.084751] Serial: AMBA PL011 UART driver
[ 1.088048] tegra_powergate_init: DONE
[ 1.091959] DTS File Name: /home/sunxuehu/work/geac_repo_manifests_jp4.6.1_545s_nx_r2.0/code/source/kernel_src/kernel/kernel-4.9/arch/arm6i
[ 1.115037] DTB Build time: Apr 20 2022 13:14:34
[ 1.124704] Tegra reboot handler registered.
[ 1.133577] tegra194-pinctrl 2430000.pinmux: function 'shutdown' not supported
[ 1.133770] tegra194-pinctrl 2430000.pinmux: invalid function shutdown in map table
[ 1.139414] tegra194-pinctrl 2430000.pinmux: Failed to add default setting: -22
[ 1.157222] iommu: Adding device 14180000.pcie to group 0
[ 1.158431] iommu: Adding device 14100000.pcie to group 1
[ 1.159534] iommu: Adding device 14140000.pcie to group 2
[ 1.164252] iommu: Adding device 14160000.pcie to group 3
[ 1.169458] iommu: Adding device 141a0000.pcie to group 4
[ 1.175651] iommu: Adding device 2490000.ether_qos to group 5
[ 1.180274] iommu: Adding device 3100000.serial to group 6
[ 1.185607] iommu: Adding device 3110000.serial to group 7
[ 1.191168] iommu: Adding device 3140000.serial to group 8
[ 1.196281] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.203163] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 1.208531] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 1.214803] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 1.220753] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.225479] tegra-pmc: PMC Prod config success
[ 1.230282] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 1.237076] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 1.244125] iommu: Adding device 3460000.sdhci to group 9
[ 1.249535] iommu: Adding device 3400000.sdhci to group 10
[ 1.254756] iommu: Adding device 3210000.spi to group 11
[ 1.260653] iommu: Adding device c260000.spi to group 12
[ 1.265724] iommu: Adding device 3230000.spi to group 13
[ 1.271778] iommu: Adding device 3160000.i2c to group 14
[ 1.276849] iommu: Adding device c240000.i2c to group 15
[ 1.282155] iommu: Adding device 3180000.i2c to group 16
[ 1.287570] iommu: Adding device 3190000.i2c to group 17
[ 1.293082] iommu: Adding device 31b0000.i2c to group 18
[ 1.298323] iommu: Adding device 31c0000.i2c to group 19
[ 1.303830] iommu: Adding device c250000.i2c to group 20
[ 1.309476] iommu: Adding device 31e0000.i2c to group 21
[ 1.315663] iommu: Adding device sound to group 22
[ 1.320044] iommu: Adding device 3510000.hda to group 23
[ 1.325429] iommu: Adding device bc00000.rtcpu to group 24
[ 1.332874] iommu: Adding device 13e10000.host1x to group 25
[ 1.336113] iommu: Adding device 13e10000.host1x:ctx0 to group 26
[ 1.342209] iommu: Adding device 13e10000.host1x:ctx1 to group 27
[ 1.348541] iommu: Adding device 13e10000.host1x:ctx2 to group 28
[ 1.354316] iommu: Adding device 13e10000.host1x:ctx3 to group 29
[ 1.360655] iommu: Adding device 13e10000.host1x:ctx4 to group 30
[ 1.366617] iommu: Adding device 13e10000.host1x:ctx5 to group 31
[ 1.372938] iommu: Adding device 13e10000.host1x:ctx6 to group 32
[ 1.378877] iommu: Adding device 13e10000.host1x:ctx7 to group 33
[ 1.385255] iommu: Adding device 15340000.vic to group 34
[ 1.390358] iommu: Adding device 15380000.nvjpg to group 35
[ 1.395731] iommu: Adding device 15500000.tsec to group 36
[ 1.401388] iommu: Adding device 15100000.tsecb to group 37
[ 1.407206] iommu: Adding device 15480000.nvdec to group 38
[ 1.412778] iommu: Adding device 15140000.nvdec1 to group 39
[ 1.418375] iommu: Adding device 154c0000.nvenc to group 40
[ 1.423789] iommu: Adding device 15a80000.nvenc1 to group 41
[ 1.429511] iommu: Adding device 15880000.nvdla0 to group 42
[ 1.435350] iommu: Adding device 158c0000.nvdla1 to group 43
[ 1.440854] iommu: Adding device 15200000.nvdisplay to group 44
[ 1.447423] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 1.453760] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 1.462062] iommu: Adding device 15c10000.vi to group 45
[ 1.466003] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 1.472577] iommu: Adding device 14800000.isp to group 46
[ 1.478713] iommu: Adding device 16000000.pva0 to group 47
[ 1.483511] iommu: Adding device 16800000.pva1 to group 48
[ 1.488530] iommu: Adding device 15810000.se to group 49
[ 1.494041] iommu: Adding device 15820000.se to group 50
[ 1.499070] iommu: Adding device 15830000.se to group 51
[ 1.504444] iommu: Adding device 15840000.se to group 52
[ 1.510134] iommu: Adding device c1a0000.aon to group 53
[ 1.517587] iommu: Adding device d000000.bpmp to group 54
[ 1.520960] bpmp: ping status is 0
[ 1.524172] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 1.535485] bpmp d000000.bpmp: probe ok
[ 1.537883] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 1.541435] iommu: Adding device smmu_test to group 55
[ 1.547172] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 1.552238] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 1.559040] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 1.565307] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 1.571642] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 1.577780] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 1.584422] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 1.590635] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 1.597197] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 1.603931] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 1.610406] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 1.616886] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 1.623292] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 1.629406] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 1.635776] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 1.642168] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 1.648557] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 1.655060] mc-err: mcerr ops are set to t19x
[ 1.667579] iommu: Adding device 2600000.dma to group 56
[ 1.674971] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[ 1.676739] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.680210] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.697484] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[ 1.698193] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.708982] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 1.712435] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.718293] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.726116] iommu: Adding device 3550000.xudc to group 57
[ 1.731584] iommu: Adding device 3610000.xhci to group 58
[ 1.739328] arm64_ras arm64_ras: probed
[ 1.740231] ras_fhi_enable: FHI 474 enabled on CPU0
[ 1.745139] ras_fhi_enable: FHI 475 enabled on CPU1
[ 1.750029] ras_fhi_enable: FHI 476 enabled on CPU2
[ 1.754659] ras_fhi_enable: FHI 477 enabled on CPU3
[ 1.759919] ras_fhi_enable: FHI 478 enabled on CPU4
[ 1.764606] ras_fhi_enable: FHI 479 enabled on CPU5
[ 1.769844] ras_fhi_enable: FHI 480 enabled on CPU6
[ 1.774794] ras_fhi_enable: FHI 481 enabled on CPU7
[ 1.779868] carmel_ras_enable: RAS enabled on cpu0
[ 1.784568] carmel_ras_enable: RAS enabled on cpu1
[ 1.789448] carmel_ras_enable: RAS enabled on cpu2
[ 1.794713] carmel_ras_enable: RAS enabled on cpu3
[ 1.799624] carmel_ras_enable: RAS enabled on cpu4
[ 1.804252] carmel_ras_enable: RAS enabled on cpu5
[ 1.809414] carmel_ras_enable: RAS enabled on cpu6
[ 1.814052] carmel_ras_enable: RAS enabled on cpu7
[ 1.819101] carmel_ras carmel_ras: probed
[ 1.824726] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 1.831438] tegra-cbb c600000.aon-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 1.839809] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 1.847715] tegra-cbb be00000.rce-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[ 1.855073] tegra-cbb b600000.sce-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 1.862004] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.872980] vdd-3v3-cvb: 3300 mV
[ 1.873523] vdd-1v8-cvb: 1800 mV
[ 1.875402] vdd-1v8-sd: 1800 mV
[ 1.878766] vdd-epb-1v0: 1000 mV
[ 1.882088] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.886708] vdd-sdmmc1-sw: 3300 mV
[ 1.890492] avdd-cam-2v8: 2800 mV
[ 1.893397] vdd-sata-1v5: 1500 mV
[ 1.897169] vdd-1v8-slt: 1800 mV
[ 1.900267] vdd-3v3-slt: 3300 mV
[ 1.903936] vdd-fan: 5000 mV
[ 1.907204] vdd-hdmi-5v0: 5000 mV
[ 1.910564] vdd_sys_en: 1200 mV
[ 1.913553] vdd-5v-sata: 5000 mV
[ 1.917298] vdd-3v3-pcie: 3300 mV
[ 1.920760] vdd-12v-pcie: 1200 mV
[ 1.923880] vdd-ac-bat: 5000 mV
[ 1.926952] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.968939] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.975074] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.975639] SCSI subsystem initialized
[ 1.976328] usbcore: registered new interface driver usbfs
[ 1.976549] usbcore: registered new interface driver hub
[ 1.976783] usbcore: registered new device driver usb
[ 1.980341] pca953x 0-0074: reg get err: -19
[ 1.994012] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.997662] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 2.008403] vdd-1v0: at 1000 mV
[ 2.014105] vdd-1v8-hs: at 1800 mV
[ 2.018148] vdd-1v8-ls: at 1800 mV
[ 2.022176] vdd-1v8-ao: at 1800 mV
[ 2.026150] vddio-ddr-1v1: at 1100 mV
[ 2.029937] vdd-rtc: at 800 mV
[ 2.031417] spmic-ldo1: at 2375 mV
[ 2.037993] vdd-ao-3v3: at 3300 mV
[ 2.046087] vddio-emmc-3v3: at 3300 mV
[ 2.047633] spmic-ldo4: at 1587 mV
[ 2.054123] vdd-usb-3v3: at 3300 mV
[ 2.062180] vddio-sdmmc1-3v3: at 3300 mV
[ 2.066251] vdd-csi-1v2: at 1200 mV
[ 2.068150] spmic-ldo8: at 1800 mV
[ 2.073771] GPIO line 246 (gpio_default) hogged as output/high
[ 2.075379] GPIO line 247 (gpio_default) hogged as output/high
[ 2.075962] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 2.076593] max77620 4-003c: max77620 probe successful
[ 2.077540] media: Linux media interface: v0.10
[ 2.077743] Linux video capture interface: v2.00
[ 2.079631] pps_core: LinuxPPS API ver. 1 registered
[ 2.079788] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.082804] PTP clock support registered
[ 2.090256] trusty trusty: trusty version: Built: 08:57:16 Feb 19 2022
[ 2.093404] trusty trusty: selected api version: 3 (requested 3)
[ 2.100586] Advanced Linux Sound Architecture Driver Initialized.
[ 2.105759] Bluetooth: Core ver 2.22
[ 2.108950] NET: Registered protocol family 31
[ 2.112911] Bluetooth: HCI device and connection manager initialized
[ 2.119470] Bluetooth: HCI socket layer initialized
[ 2.124626] Bluetooth: L2CAP socket layer initialized
[ 2.129561] Bluetooth: SCO socket layer initialized
[ 2.137896] camchar: rtcpu character device driver loaded
[ 2.140620] gpio tegra-gpio wake35 for gpio=128(Q:0)
[ 2.145091] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 2.154766] clocksource: Switched to clocksource arch_sys_counter
[ 2.215212] VFS: Disk quotas dquot_6.6.0
[ 2.215444] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.216132] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.218610] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 2.218959] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 2.219177] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 2.219338] nvmap_page_pool_init: Total RAM pages: 8135929
[ 2.219512] nvmap_page_pool_init: nvmap page pool size: 1016991 pages (3972 MB)
[ 2.220016] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.220584] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 2.221710] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 2.247921] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 2.248596] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 2.251487] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 2.260324] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 2.268416] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 2.276621] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 2.285543] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 2.295776] la/ptsa driver initialized.
[ 2.298719] NET: Registered protocol family 2
[ 2.302623] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 2.314655] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 2.318877] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 2.324772] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.330663] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 2.337240] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 2.344533] NET: Registered protocol family 1
[ 2.348909] RPC: Registered named UNIX socket transport module.
[ 2.354062] RPC: Registered udp transport module.
[ 2.358767] RPC: Registered tcp transport module.
[ 2.363057] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.369984] Trying to unpack rootfs image as initramfs...
[ 2.945766] Freeing initrd memory: 14808K
[ 2.967531] random: fast init done
[ 2.972635] host1x 13e10000.host1x: initialized
[ 2.976216] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.982892] audit: initializing netlink subsys (disabled)
[ 2.983099] audit: type=2000 audit(2.216:1): initialized
[ 2.984051] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.999528] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.001211] ntfs: driver 2.1.32 [Flags: R/W].
[ 3.002202] 9p: Installing v9fs 9p2000 file system support
[ 3.009313] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 3.009786] io scheduler noop registered
[ 3.010165] io scheduler cfq registered (default)
[ 3.014971] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 3.022055] iommu: Adding device 2993000.adsp to group 59
[ 3.045521] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 3.045935] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 3.065324] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 3.066144] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 3.067048] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 3.067708] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 3.072127] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 3.072694] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 3.072948] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=7500000, max_bw=7500000
[ 3.077159] tsec 15500000.tsec: initialized
[ 3.079253] tsec 15100000.tsecb: initialized
[ 3.084392] nvdec 15480000.nvdec: initialized
[ 3.088378] nvdec 15140000.nvdec1: initialized
[ 3.096443] falcon 15340000.vic: initialized
[ 3.098987] falcon 15380000.nvjpg: initialized
[ 3.101872] falcon 154c0000.nvenc: initialized
[ 3.104337] falcon 15a80000.nvenc1: initialized
[ 3.108639] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 3.111487] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 3.113669] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 3.115702] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 3.117823] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 3.119947] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 3.121926] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 3.123979] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 3.128310] t194-nvcsi 15a00000.nvcsi: initialized
[ 3.135429] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 3.136026] scare-pigeon 14b00000.isp-thi: initialized
[ 3.146450] pva 16000000.pva0: initialized
[ 3.178552] pva 16800000.pva1: initialized
[ 3.209741] nvdla 15880000.nvdla0: initialized
[ 3.240337] nvdla 158c0000.nvdla1: initialized
[ 3.242951] tegradccommon 15200000.dc_common: host1x channel mapped
[ 3.243157] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 3.243360] tegradccommon 15200000.dc_common: dma mapping done
[ 3.245378] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 3.245627] generic_infoframe_type: 0x87
[ 3.245863] tegradc 15200000.nvdisplay: DT parsed successfully
[ 3.246072] tegradc 15200000.nvdisplay: Display dc.ffffff800bcd0000 registered with id=0
[ 3.253324] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 3.253602] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 3.253826] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 3.254252] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 3.254440] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 3.259691] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 3.259872] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 3.261031] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 3.262373] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 3.266273] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 3.273961] kfuse 3830000.kfuse: initialized
[ 3.285317] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.288990] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 3.294740] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 54, base_baud = 0) is a TEGRA_UART
[ 3.303612] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 55, base_baud = 0) is a TEGRA_UART
[ 3.313106] console [ttyTCU0] enabled
[ 3.314979] tegradc 15200000.nvdisplay: probed
[ 3.327035] bootconsole [tegra_comb_uart0] disabled
[ 3.327770] Console: switching to colour frame buffer device 240x67
[ 3.349256] tegradc 15200000.nvdisplay: fb registered
[ 3.349670] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 3.359677] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.359765] [drm] Initialized
[ 3.368214] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.382560] brd: module loaded
[ 3.389675] Parent Clock set for DC plld3
[ 3.394654] loop: module loaded
[ 3.394875] tegra_profiler: version: 1.145, samples/io: 49/28
[ 3.395243] tegra_profiler: auth: init
[ 3.395623] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 3.395993] nct1008_nct72 4-004c: starting parse dt
[ 3.396156] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 3.396165] nct1008_nct72 4-004c: success parsing dt
[ 3.396306] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 3.396653] THERMAL EST: found 3 subdevs
[ 3.396667] THERMAL EST num_resources: 0
[ 3.396682] [THERMAL EST subdev 0]
[ 3.396693] [THERMAL EST subdev 1]
[ 3.396725] [THERMAL EST subdev 2]
[ 3.396746] THERMAL EST: Found 2 profiles, default profile is quiet
[ 3.397229] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.397233] THERMAL EST: thz register success.
[ 3.397491] THERMAL EST: end of probe, return err: 0
[ 3.398392] sd: No Scsi addr parsed to reserve index
[ 3.398421] hisi_sas: driver version v1.6
[ 3.409176] libphy: Fixed MDIO Bus: probed
[ 3.409957] tun: Universal TUN/TAP device driver, 1.6
[ 3.409961] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.411044] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.411062] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.411125] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.411129] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.411181] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.411185] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.411241] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 3.411245] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 3.422150] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 3.422692] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 2f fb 2d
[ 3.422715] Using phyrst_lpmode = 1 from DT
[ 3.422852] libphy: dwc_phy: probed
[ 3.425573] PPP generic driver version 2.4.2
[ 3.425822] PPP BSD Compression module registered
[ 3.425828] PPP Deflate Compression module registered
[ 3.425845] PPP MPPE Compression module registered
[ 3.425851] NET: Registered protocol family 24
[ 3.425942] usbcore: registered new interface driver r8152
[ 3.425998] usbcore: registered new interface driver asix
[ 3.426041] usbcore: registered new interface driver ax88179_178a
[ 3.426076] usbcore: registered new interface driver cdc_ether
[ 3.426144] usbcore: registered new interface driver net1080
[ 3.426186] usbcore: registered new interface driver cdc_subset
[ 3.426233] usbcore: registered new interface driver zaurus
[ 3.426304] usbcore: registered new interface driver cdc_ncm
[ 3.426493] VFIO - User Level meta-driver version: 0.3
[ 3.428077] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.428133] ehci-pci: EHCI PCI platform driver
[ 3.428190] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.428202] ohci-pci: OHCI PCI platform driver
[ 3.428249] ohci-platform: OHCI generic platform driver
[ 3.431092] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 3.431860] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 3.436144] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 3.440247] usbcore: registered new interface driver uas
[ 3.440303] usbcore: registered new interface driver usb-storage
[ 3.440390] usbcore: registered new interface driver usbserial
[ 3.441673] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 3.441721] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.441742] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 3.442491] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 3.442537] tegra-xusb 3610000.xhci: irq 469, io mem 0x03610000
[ 3.442859] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.442866] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.442872] usb usb1: Product: xHCI Host Controller
[ 3.442878] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 3.442884] usb usb1: SerialNumber: 3610000.xhci
[ 3.443600] hub 1-0:1.0: USB hub found
[ 3.443752] hub 1-0:1.0: 4 ports detected
[ 3.444751] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.444766] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 3.444810] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.445284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.445292] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.445299] usb usb2: Product: xHCI Host Controller
[ 3.445306] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 3.445311] usb usb2: SerialNumber: 3610000.xhci
[ 3.446125] hub 2-0:1.0: USB hub found
[ 3.446293] hub 2-0:1.0: 4 ports detected
[ 3.446520] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 3.446627] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.447435] Wake76 for irq=199
[ 3.447439] Wake77 for irq=199
[ 3.447443] Wake78 for irq=199
[ 3.447446] Wake79 for irq=199
[ 3.447449] Wake80 for irq=199
[ 3.447453] Wake81 for irq=199
[ 3.447456] Wake82 for irq=199
[ 3.447502] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 3.447509] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 3.447839] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 3.447851] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 3.447882] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.448137] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.448973] mousedev: PS/2 mouse device common for all mice
[ 3.449095] usbcore: registered new interface driver xpad
[ 3.468810] nct1008_nct72 4-004c: initial LOC temp: 34000
[ 3.469368] nct1008_nct72 4-004c: initial EXT temp: 45500
[ 3.470394] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 3.471488] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 3.555319] usb usb2: usb_suspend_both: status 0
[ 3.580726] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.582521] Wake73 for irq=42
[ 3.583805] rtc rtc1: alarm rtc device
[ 3.583823] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.583866] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.584092] i2c /dev entries driver
[ 3.585857] pca954x 2-0070: vcc regualtor get failed, -19
[ 3.588032] pps pps0: new PPS source pps.-1
[ 3.588104] pps pps0: Registered IRQ 431 as PPS source
[ 3.588718] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[ 3.598525] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 3.599177] FAN dev name: pwm-fan
[ 3.599240] FAN:gpio request success.
[ 3.599251] FAN: can't find tach_gpio
[ 3.599266] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 3.599327] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 3.599616] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 3.599623] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.600419] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.600427] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 3.600434] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.600441] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.600448] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.600454] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.600465] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.600471] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.600478] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.600485] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.601468] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 3.602814] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 3.603437] device-mapper: uevent: version 1.0.3
[ 3.603866] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.618967] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 3.624565] cpuidle: Initializing cpuidle driver
[ 3.636534] sdhci: Secure Digital Host Controller Interface driver
[ 3.636537] sdhci: Copyright(c) Pierre Ossman
[ 3.636538] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.637783] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.639971] CMDQ: cmdq_platfm_init successful
[ 3.640407] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.643182] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.644645] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 253
[ 3.686777] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.695769] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 3.695808] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.774771] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 3.798406] usb 1-3: New USB device found, idVendor=046d, idProduct=c534
[ 3.798410] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.798413] usb 1-3: Product: USB Receiver
[ 3.798415] usb 1-3: Manufacturer: Logitech
[ 3.918781] usb 1-4: new full-speed USB device number 3 using tegra-xusb
[ 3.919130] usb 1-4: Device not responding to setup address.
[ 4.100472] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.112508] mmc0: periodic cache flush enabled
[ 4.112515] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.112952] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.113168] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 4.113335] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 4.113489] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 4.116649] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p4
[ 4.131071] usb 1-4: Device not responding to setup address.
[ 4.326519] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.334774] usb 1-4: device not accepting address 3, error -71
[ 4.366105] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.366238] Extcon AUX2(HDMI) enable
[ 4.369017] tegra-se-nvhost 15810000.se: initialized
[ 4.370242] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.371552] tegra-se-nvhost 15820000.se: initialized
[ 4.372913] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.374315] tegra-se-nvhost 15830000.se: initialized
[ 4.375797] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.382936] tegra-se-nvhost 15840000.se: initialized
[ 4.387475] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.393697] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.399452] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.407330] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-3/1-3:1.0/0003:046D:C534.0001/input/input0
[ 4.458848] usb 1-4: new high-speed USB device number 4 using tegra-xusb
[ 4.471378] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-3/input0
[ 4.475099] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-3/1-3:1.1/0003:046D:C534.0002/input/input1
[ 4.497902] usb 1-4: New USB device found, idVendor=1c9e, idProduct=9b3c
[ 4.498068] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.498197] usb 1-4: Product: USB Modem
[ 4.498262] usb 1-4: Manufacturer: LONGSUNG
��WARNING: pll_d3 has no dyn ramp
��[ 4.498561] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.535198] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-3/input1
[ 4.535251] usbcore: registered new interface driver usbhid
[ 4.535272] usbhid: USB HID core driver
[ 4.540956] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.542047] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.542558] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.543278] denver_knobs_init:MTS_VERSION:54811859
[ 4.543612] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 4.544405] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.544952] t19x_cache tegra-cache: probed
[ 4.548291] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 4.548294] Extcon AUX2(HDMI) disable
[ 4.551299] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.551319] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.551915] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 4.552296] Clocks initialized successfully
[ 4.553782] nvpmodel: initialized successfully
[ 4.555237] trusty-virtio trusty:virtio: initializing
[ 4.555404] trusty_ipc virtio0: vring0: va(pa) ffffffc7d6642000(0) qsz 32 notifyid 1
[ 4.555413] trusty_ipc virtio0: vring1: va(pa) ffffffc7d664c000(0) qsz 32 notifyid 2
[ 4.555526] trusty-virtio trusty:virtio: initializing done
[ 4.555687] trusty_ipc virtio0: is online
[ 4.556283] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.556679] usbcore: registered new interface driver snd-usb-audio
[ 4.568283] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input2
[ 4.568445] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input3
[ 4.568595] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input4
[ 4.568748] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input5
[ 4.570658] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.571371] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.602324] tegradc 15200000.nvdisplay: unblank
[ 4.603355] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.603506] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.605876] Parent Clock set for DC plld3
[ 4.612541] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4.613873] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.649046] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.649049] Extcon AUX2(HDMI) enable
[ 4.664023] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 4.852391] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 4.859547] Extcon HDMI: HPD enabled
[ 4.862958] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.891457] tegra-i2c c250000.i2c: no acknowledge from address 0x1a
[ 4.893003] rt5659 7-001a: Device with ID register ffffff80 is not rt5659
[ 4.975775] OPE platform probe
[ 4.977454] OPE platform probe successful
[ 4.989019] u32 classifier
[ 4.990592] Actions configured
[ 4.993347] Initializing XFRM netlink socket
[ 4.995418] NET: Registered protocol family 10
[ 4.998557] NET: Registered protocol family 17
[ 5.000035] NET: Registered protocol family 15
[ 5.001672] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need.
[ 5.003382] Bluetooth: RFCOMM socket layer initialized
[ 5.004905] Bluetooth: RFCOMM ver 1.11
[ 5.006349] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.007843] Bluetooth: HIDP socket layer initialized
[ 5.009358] 9pnet: Installing 9P2000 support
[ 5.011000] Key type dns_resolver registered
[ 5.012695] Registered cp15_barrier emulation handler
[ 5.014153] Registered setend emulation handler
[ 5.017412] registered taskstats version 1
[ 5.019281] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 5.021671] OF: PCI: host bridge /pcie@14180000 ranges:
[ 5.023151] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 5.024549] OF: PCI: MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[ 5.025915] OF: PCI: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 5.540923] tegra-pcie-dw 14180000.pcie: link is down
[ 5.542426] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.543768] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.545053] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.546411] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.547813] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.549526] iommu: Adding device 0000:00:00.0 to group 61
[ 5.551038] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.552323] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.553879] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.555754] iommu: Removing device 0000:00:00.0 from group 61
[ 5.558561] tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
[ 5.560433] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 5.562552] OF: PCI: host bridge /pcie@14100000 ranges:
[ 5.563859] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 5.565429] OF: PCI: MEM 0x1230000000..0x123fffffff -> 0x40000000
[ 5.567561] OF: PCI: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 5.678830] tegra-pcie-dw 14100000.pcie: link is up
[ 5.680348] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.681655] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.682956] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.684298] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.685681] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.687423] iommu: Adding device 0001:00:00.0 to group 61
[ 5.690199] pci 0001:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.691749] pci 0001:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.693638] iommu: Adding device 0001:01:00.0 to group 62
[ 5.696308] pci 0001:01:00.1: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.697851] pci 0001:01:00.1: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.699769] iommu: Adding device 0001:01:00.1 to group 63
[ 5.702471] pci 0001:01:00.2: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.704085] pci 0001:01:00.2: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.711600] iommu: Adding device 0001:01:00.2 to group 64
[ 5.717956] pci 0001:01:00.3: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.727012] pci 0001:01:00.3: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.737257] iommu: Adding device 0001:01:00.3 to group 65
[ 5.752144] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 5.753573] pci 0001:00:00.0: BAR 15: assigned [mem 0x1200000000-0x12000fffff 64bit pref]
[ 5.757902] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 5.764713] pci 0001:01:00.0: BAR 0: assigned [mem 0x1230000000-0x123001ffff]
[ 5.772129] pci 0001:01:00.1: BAR 0: assigned [mem 0x1230020000-0x123003ffff]
[ 5.779199] pci 0001:01:00.2: BAR 0: assigned [mem 0x1230040000-0x123005ffff]
[ 5.786456] pci 0001:01:00.3: BAR 0: assigned [mem 0x1230060000-0x123007ffff]
[ 5.793786] pci 0001:01:00.0: BAR 3: assigned [mem 0x1230080000-0x1230083fff]
[ 5.801118] pci 0001:01:00.0: BAR 7: assigned [mem 0x1200000000-0x120001ffff 64bit pref]
[ 5.809475] pci 0001:01:00.0: BAR 10: assigned [mem 0x1200020000-0x120003ffff 64bit pref]
[ 5.817536] pci 0001:01:00.1: BAR 3: assigned [mem 0x1230084000-0x1230087fff]
[ 5.824933] pci 0001:01:00.1: BAR 7: assigned [mem 0x1200040000-0x120005ffff 64bit pref]
[ 5.833774] pci 0001:01:00.1: BAR 10: assigned [mem 0x1200060000-0x120007ffff 64bit pref]
[ 5.841135] pci 0001:01:00.2: BAR 3: assigned [mem 0x1230088000-0x123008bfff]
[ 5.848497] pci 0001:01:00.2: BAR 7: assigned [mem 0x1200080000-0x120009ffff 64bit pref]
[ 5.856500] pci 0001:01:00.2: BAR 10: assigned [mem 0x12000a0000-0x12000bffff 64bit pref]
[ 5.864706] pci 0001:01:00.3: BAR 3: assigned [mem 0x123008c000-0x123008ffff]
[ 5.871549] pci 0001:01:00.3: BAR 7: assigned [mem 0x12000c0000-0x12000dffff 64bit pref]
[ 5.879985] pci 0001:01:00.3: BAR 10: assigned [mem 0x12000e0000-0x12000fffff 64bit pref]
[ 5.887989] pci 0001:01:00.0: BAR 2: assigned [io 0x100000-0x10001f]
[ 5.894572] pci 0001:01:00.1: BAR 2: assigned [io 0x100020-0x10003f]
[ 5.901127] pci 0001:01:00.2: BAR 2: assigned [io 0x100040-0x10005f]
[ 5.907236] pci 0001:01:00.3: BAR 2: assigned [io 0x100060-0x10007f]
[ 5.914048] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.919047] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 5.925375] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 5.932799] pci 0001:00:00.0: bridge window [mem 0x1200000000-0x12000fffff 64bit pref]
[ 5.940764] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.949591] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.957804] pci 0001:01:00.1: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.966403] pci 0001:01:00.2: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.975123] pci 0001:01:00.3: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.983512] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.990336] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.997057] pci 0001:01:00.1: Signaling PME through PCIe PME interrupt
[ 6.003176] pci 0001:01:00.2: Signaling PME through PCIe PME interrupt
[ 6.010004] pci 0001:01:00.3: Signaling PME through PCIe PME interrupt
[ 6.016664] igb 0001:01:00.0: enabling device (0000 -> 0002)
[ 6.099186] igb 0001:01:00.0: added PHC on eth1
[ 6.100376] igb 0001:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 6.101593] igb 0001:01:00.0: eth1: (PCIe:5.0Gb/s:Width x1) 00:54:5a:15:01:1b
[ 6.103031] igb 0001:01:00.0: eth1: PBA No: 106300-000
[ 6.104186] igb 0001:01:00.0: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 6.105833] igb 0001:01:00.1: enabling device (0000 -> 0002)
[ 6.183752] igb 0001:01:00.1: added PHC on eth2
[ 6.184920] igb 0001:01:00.1: Intel(R) Gigabit Ethernet Network Connection
[ 6.186111] igb 0001:01:00.1: eth2: (PCIe:5.0Gb/s:Width x1) 00:54:5a:15:01:1c
[ 6.188692] igb 0001:01:00.1: eth2: PBA No: 106300-000
[ 6.189920] igb 0001:01:00.1: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 6.191578] igb 0001:01:00.2: enabling device (0000 -> 0002)
[ 6.269735] igb 0001:01:00.2: added PHC on eth3
[ 6.270937] igb 0001:01:00.2: Intel(R) Gigabit Ethernet Network Connection
[ 6.272153] igb 0001:01:00.2: eth3: (PCIe:5.0Gb/s:Width x1) 00:54:5a:15:01:1d
[ 6.273567] igb 0001:01:00.2: eth3: PBA No: 106300-000
[ 6.274725] igb 0001:01:00.2: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 6.276387] igb 0001:01:00.3: enabling device (0000 -> 0002)
[ 6.354212] igb 0001:01:00.3: added PHC on eth4
[ 6.355387] igb 0001:01:00.3: Intel(R) Gigabit Ethernet Network Connection
[ 6.356561] igb 0001:01:00.3: eth4: (PCIe:5.0Gb/s:Width x1) 00:54:5a:15:01:1e
[ 6.357963] igb 0001:01:00.3: eth4: PBA No: 106300-000
[ 6.359132] igb 0001:01:00.3: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 6.360565] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 6.362631] OF: PCI: host bridge /pcie@14140000 ranges:
[ 6.363798] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 6.364902] OF: PCI: MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[ 6.366024] OF: PCI: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 6.474850] tegra-pcie-dw 14140000.pcie: link is up
[ 6.476170] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.477286] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.478359] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.479568] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.480766] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.482279] iommu: Adding device 0003:00:00.0 to group 66
[ 6.484895] iommu: Adding device 0003:01:00.0 to group 67
[ 6.496059] pci 0003:00:00.0: BAR 14: assigned [mem 0x12b0000000-0x12b00fffff]
[ 6.497232] pci 0003:01:00.0: BAR 0: assigned [mem 0x12b0000000-0x12b0001fff 64bit]
[ 6.498480] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.499659] pci 0003:00:00.0: bridge window [mem 0x12b0000000-0x12b00fffff]
[ 6.500827] pci 0003:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.502072] pci 0003:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 6.503475] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.504652] pci 0003:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.506353] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 6.508332] OF: PCI: host bridge /pcie@14160000 ranges:
[ 6.510716] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 6.516713] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 6.522795] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 6.638889] tegra-pcie-dw 14160000.pcie: link is up
[ 6.640331] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.641548] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.642719] pci_bus 0004:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x36100000-0x361fffff])
[ 6.644019] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 6.645347] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 6.648050] iommu: Adding device 0004:00:00.0 to group 68
[ 6.650967] iommu: Adding device 0004:01:00.0 to group 69
[ 6.663771] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 6.665039] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740003fff 64bit]
[ 6.666427] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.667721] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 6.669022] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.670423] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.671978] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.673275] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.675075] nvme nvme0: pci function 0004:01:00.0
[ 6.676386] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 6.676674] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.790723] nvme0n1: p1
[ 6.891128] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.892469] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 6.893800] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 6.895122] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 7.412118] tegra-pcie-dw 141a0000.pcie: link is down
[ 7.413580] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.414935] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.416230] pci_bus 0005:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.417600] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 7.419003] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 7.420734] iommu: Adding device 0005:00:00.0 to group 70
[ 7.422269] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.423608] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.425191] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.427055] iommu: Removing device 0005:00:00.0 from group 70
[ 7.430291] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 7.446354] tegra-cbb 14040000.cv-noc: noc_secure_irq = 97, noc_nonsecure_irq = 96>
[ 7.453800] tegra194-isp5 14800000.isp: initialized
[ 7.460539] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 7.466945] tegra194-vi5 15c10000.vi: initialized
[ 7.472245] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--8 bound
[ 7.473697] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--7 bound
[ 7.475141] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--6 bound
[ 7.476529] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--5 bound
[ 7.477881] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--4 bound
[ 7.479239] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--3 bound
[ 7.480599] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 7.481920] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 7.483380] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 7.544062] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 7.545413] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 7.546787] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 7.548203] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 7.549534] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 7.550816] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 7.556942] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 7.558229] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 7.559491] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 7.568163] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 7.575574] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 7.585669] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 7.595711] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 7.604157] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 7.612606] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 7.621961] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 7.630722] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.658800] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: response timeout
[ 9.660009] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 1/2
[ 11.674807] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 11.676059] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 2/2
[ 13.690801] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 13.692472] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfec0000-0xbfedffff size=131072
[ 13.694113] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 13.695597] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 13.697034] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 13.698724] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 13.700135] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 13.701646] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (73)
[ 13.703154] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 13.705151] tegra186-cam-rtcpu bc00000.rtcpu: fw version 0 has no sha1
[ 15.706823] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x06bfec00: empty mailbox timeout
[ 15.708115] tegra-hsp-mailbox ivc-bc00000.rtcpu: IOVM setup error: 110
[ 15.709353] tegra186-cam-rtcpu bc00000.rtcpu: ivc-bus boot sync failed: -5
[ 15.710590] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=0 sha1=0000000000000000000000000000000000000000
[ 15.745878] tegra_rtc c2a0000.rtc: setting system clock to 2022-01-11 04:12:58 UTC (1641874378)
[ 15.747762] mmcblk mmc0:0001: Card claimed for testing.
[ 15.797314] bpmp: mounted debugfs mirror
[ 15.803680] ALSA device list:
[ 15.804895] #0: tegra-hda-galen-t194 at 0x3518000 irq 72
[ 15.807544] Freeing unused kernel memory: 8640K
[ 15.843591] Root device found: initrd
[ 15.846271] Mount initrd as rootfs and enter recovery mode
enable_remote_access
enable remote access
[ 15.882467] using random self ethernet address
[ 15.883794] using random host ethernet address
[ 15.891840] Mass Storage Function, version: 2009/09/11
[ 15.893096] LUN: removable file: (no medium)
Add mmcblk0
[ 15.897112] LUN: removable file: (no medium)
Add mmcblk0boot0
[ 15.900988] LUN: removable file: (no medium)
Add mmcblk0boot1
[ 15.904921] LUN: removable file: (no medium)
Add /dev/nvme0n1
[ 15.911452] rndis0: HOST MAC 76:5f:cb:68:91:73
[ 15.912690] rndis0: MAC 1a:11:70:61:19:1f
[ 15.913949] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 15.915825] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 15.917019] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 15.918193] tegra-xudc-new 3550000.xudc: entering ELPG
[ 15.919540] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 15.920665] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 15.922285] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 15.923340] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 15.924603] tegra-xudc-new 3550000.xudc: entering ELPG
[ 15.925917] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 15.950122] random: sshd: uninitialized urandom read (32 bytes read)
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-4.4# [ 46.810906] vdd-1v8-cvb: disabling
[ 46.812068] vdd-1v8-sd: disabling
[ 46.813164] vdd-epb-1v0: disabling
[ 46.814246] vdd-sdmmc1-sw: disabling
[ 46.815333] avdd-cam-2v8: disabling
[ 46.816403] vdd-sata-1v5: disabling
[ 46.817497] vdd-3v3-slt: disabling
[ 46.818567] vdd-fan: disabling
[ 46.819647] vdd_sys_en: disabling
[ 46.820716] vdd-5v-sata: disabling
[ 46.821770] vdd-3v3-pcie: disabling
[ 46.822843] vdd-12v-pcie: disabling
and the screen freezes
