Disk Encryption on Jetson Orin Nano Without Secure Boot or UEFI Secure Boot
It seems not the expected result to me.
You have to use the your own oem_k1 key (which is used to burn the fuse) to create the key for disk encryption.
The default key should not work with your fuse board.
Maybe you used the default oem_k1 key to burn the fuse…!?
