Thanks for the confirmation, @JerryChang. I did try locally with mixed results. Some attempts worked, so that’s a win.
Setup: Orin Nano carrier board, 2x Orin NX SoMs which I didn’t experiment with in the disk encryption setup, they were previously flashed without any security features with JP 5.1.2.
- Clean Linux_for_Tegra. Only your commands from above.
- Orin SoM #1
- flashed and booted succesfully with encryption working.
- Switched the SoM to Orin #2.
- Ran only command 4.
- Orin booted but hung with
ERROR: fail to unlock the encrypted dev /dev/nvme0n1p2.
- Clean Linux_for_Tegra. Again only your commands.
- Orin SoM #2
- worked, booted succesfully.
- In the same environment, run all the commands again
- Command 4 failed with
Error: Could not stat device /dev/mmcblk0 - No such file or directory.
. This replicates every time you run the commands again.
- Switched back to Orin SoM #1
- Booted, but in recovery mode from the 1st boot
L4TLauncher: Attempting Recovery Boot
- Failed later with
[ 7.494074] Root device found: initrd
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.120-tegra
[ 7.496146] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
mount /dev/nvme0n1p1 /mnt
[ 7.520214] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
is_boot_only_partition /mnt
The mounted /dev/nvme0n1p1 is boot partition, try locating rootfs partition and mount it...
mount_rootfs_partition /dev/nvme0n1p1 /mnt
Found encrypted rootfs partition /dev/nvme0n1p2 through UUID(aa83d09a-41cb-4239-bebd-f682d7814032)
umount /mnt
unlock_encrypted_partition /dev/nvme0n1p2 dm_crypt_ota dm_crypt
is_luks_partition /dev/nvme0n1p2
is_unlocked /dev/nvme0n1p2 unlocked_device_name
get_uuid_for_luks_partition /dev/nvme0n1p2 luks_uuid
No key available with this passphrase.
Failed to unlock the LUKS partition /dev/nvme0n1p2(UUID=aa83d09a-41cb-4239-bebd-f682d7814032)
Failed to run "unlock_encrypted_partition /dev/nvme0n1p2 dm_crypt_ota dm_crypt"
Failed to run "moutn_rootfs_partition /dev/nvme0n1p1 /mnt"
Failed to run "mount_ota_work_partition /dev/nvme0n1p1 /mnt"
Finding OTA work dir on internal storage device
mount /dev/mmcblk0p1 /mnt
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 on the /mnt
Failed to run "mount_ota_work_partition /dev/mmcblk0p1 /mnt"
OTA work directory is not found on internal and external storage devices
- Orin SoM #1
- Switch to SoM #2
- Run only command #4. Same error.
So it seems that the commands work…sometimes :-?. But sometimes fail even with a clean environment.
I’ll try to change to a custom key and add Secureboot to the setup, see how that goes.
Thanks for your help!
