Hi, we are trying to encrypt rootfs on a system that has the rt-patch applied. We have been using r35.4.1 on the Agx Orin dev-kit and our current pipeline is to
- build the kernel and apply the patch according to Kernel Customization — Jetson Linux Developer Guide documentation.
- follow the instructions in Disk Encryption — Jetson Linux<br/>Developer Guide 34.1 documentation to encrypt rootfs + flash to mmcblk0p1.
If we follow this pipeline without applying rt-patch, the Orin boots fine and lsblk shows that the rootfs is encrypted. However, following the same pipeline with rt-patch applied causes the Orin to fail to boot. Can we get a confirmation as to whether disk encryption works with preempt-RT?
Here’s the boot logs from the debug port if it’s any help:
debuglogs.txt (54.5 KB)
