I’m working on kernel6.6 for jetson, and have same situations!
when the system quit uefi, enter kernel6.6, the Displayport(DP) is blank.
This is My kernel log:
Ker6.6+Ubuntu无显示启动内核log.txt (78.5 KB)
and i fount that drm does’nt work, so drm no any device at /sys/class/drm.
That’s not we currently used and haven’t try that. If roll back to JP6 GA/K5.15, can issue happen?
All of project is base on Jetpack6/Kernel5.15, I just replace the kernel:
and I chenge the kernel5.15(/boot/Image), othe module no change, the displayport is ok.
and I find the error may be at(Linux_for_Tegra/source/nvidia-oot/drivers/gpu/drm/tegra/drm.c) :
static int host1x_drm_probe(struct host1x_device *dev)
static struct host1x_driver host1x_drm_driver = {
.driver = {
.name = "drm",
.pm = &host1x_drm_pm_ops,
.probe = host1x_drm_probe,
.remove = host1x_drm_remove,
.subdevs = host1x_drm_subdevs,
static int __init host1x_drm_init(void)
int err;
#if LINUX_VERSION_CODE >= KERNEL_VERSION(5, 18, 0)
if (drm_firmware_drivers_only())
return -ENODEV;
#endif
err = host1x_driver_register(&host1x_drm_driver);
if (err < 0)
return err;
err = platform_register_drivers(drivers, ARRAY_SIZE(drivers));
if (err < 0)
goto unregister_host1x;
return 0;
unregister_host1x:
host1x_driver_unregister(&host1x_drm_driver);
return err;
module_init(host1x_drm_init);
funtion: host1x_driver_register
has register driver, but the host1x_drm_probe
is not runing!
I think device is not register, but I try to print on bus_for_each_dev(kernel6.6/driver/base/bus.c)
int bus_for_each_dev(const struct bus_type *bus, struct device *start,
void *data, int (*fn)(struct device *, void *))
struct subsys_private *sp = bus_to_subsys(bus);
struct klist_iter i;
struct device *dev;
int error = 0;
if (!sp)
return -EINVAL;
klist_iter_init_node(&sp->klist_devices, &i,
(start ? &start->p->knode_bus : NULL));
while (!error && (dev = next_device(&i)))
error = fn(dev, data);
klist_iter_exit(&i);
subsys_put(sp);
return error;
I found that host1x_driver_register -> host1x_driver_register_full -> driver_register -> bus_add_driver -> driver_attach -> bus_for_each_dev
on function bus_for_each_dev :
sp->klist_devices
is empty。
that means there is no device for host1x_bus_type
I solve it partly!
kernel6.6 Can show the desktop on displayport。
But no DRM instance。
