I am trying to output a 2D texture on a pixel buffer using the unsigned_int_10_10_10_2 format but am seeing the following error:
OpenGL] Error 1282 - ‘invalid operation’
[OpenGL] glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, 1920, 1080, GL_RGBA_INTEGER, GL_UNSIGNED_INT_10_10_10_2, 0)
I use the following to setup the glfw window.
glfwWindowHint(GL_RED_BITS, 10);
glfwWindowHint(GL_GREEN_BITS, 10);
glfwWindowHint(GL_BLUE_BITS, 10);
glfwWindowHint(GL_ALPHA_BITS, 2);
I use the following to setup the texImage.
glBindTexture(GL_TEXTURE_2D, m_texid);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB10_A2UI, 1920, 1080, 0, GL_RGBA_INTEGER, GL_UNSIGNED_INT_10_10_10_2, NULL);
And the following to draw for texsubImage.
GL(glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB, pixel_buffer_object));
GL(glBindTexture(GL_TEXTURE_2D, m_texid));
GL(glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, 1920, 1080, GL_RGBA_INTEGER, GL_UNSIGNED_INT_10_10_10_2, 0));
GL(glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB, 0));
Am I missing something to set it up?
