Hey,
I have an ethernet camera connected to my Jetson Nano. I can display that stream (RTP, H264) using gstreamer on my nano (gst-launch-1.0 udpsrc).
But now I want to build a WebRTC server on my Jetson Nano so that I can capture that video stream and display it in a browser. Thereby I want to stream the video on different clients in my local network just by opening the url in the browser.
How is it possible? Which repository can I use or install to use WebRTC on my nano (Ubuntu)?
Can anybody help? Thanks.
For WebRTC, we have a package to enable hardware encoding:
https://developer.nvidia.com/embedded/L4T/r32_Release_v4.3/t210ref_release_aarch64/WebRTC_R32.4.3_aarch64.tbz2
Please take a look. See if it can be applied to your usecase.
Hi
I am new to webRTC.
I just downloaded WebRTC from the link you suggested.
This is my tested output:
run ./video_loopback --codec H264 --width 2592 --height 1944 --capture_device_index 0
it can display on Jetson nano, but the video window size and aspect ratio changes frequently. why?
close the video_loopback app and run ./peerconnection_server successfully.
run ./peerconnection_client --autoconnect --server 192.168.18.10 from another terminal in the same Jetson nano platform. It opens a “PeerConnection client” window with message of “List of current connected peers:”. The server terminal window display
Question:
Why connected but not display any video?
Why server terminal display “Disconnecting socket” but with “Total connected: 1”?
- run
./peerconnection_client --server 192.168.18.10 --autoconnect --autocall from 3rd terminal in the same Jetson nano. The output has more information below:
- in server terminal:
why it repeatably display the message as above window?
- Now the video displayed in of PeerConnection client window. The other PeerConnection client window displays nothing.
Why 2 clients connected, but it displays one video window?
Other questions:
- How can I view the webRTC video from Windows 10?
- How can I make webRTC video size at 2592 x 1944 from your app?
- Is there any document on how to work with the webRTC library?
The package enables hardware encoding in certain use-cases in WebRTC. Please check the website:
https://webrtc.org/
The prebuilt application is for demonstration. For real use-case, please refer to How to use NvVideoEncoderFactory to create NvEncoder in README. By default it shoudl be software encoding in WebRTC. You can use the APIs to enable hardware encoding.
