Display freezes seemingly randomly on NixOS KDE Plamsa
I’ve been having this issue for the last year or so, today was the first time it only froze one of my displays instead of all 3 so it was a little easier to debug.
I dual boot windows and NixOS and this issue only seems to happen on linux.
When all 3 monitors freeze, I tested if any other part of my system was still operational by using KDE Connect to send a file while the OS was frozen. I was successfully able to retrieve that file so it seems that it’s just a display and possibly a sound issue.
configuration.nix.txt (21.8 KB)
flake.nix.txt (2.7 KB)
I believe it’s just a display issue and the sound only cuts off a little later because youtube shorts stop auto replaying if the display cuts out.
In the case that all 3 monitors have frozen, I notice these logs from systemd are more common (I’ll attach the entire file as well):
2026-09-05 22:59:47 GMT [Client] INFO  rs117.hd.HdPlugin - GPU:               NVIDIA GeForce RTX 3060/PCIe/SSE2 (NVIDIA Corporation)
2026-09-05 22:59:47 GMT [Client] INFO  rs117.hd.HdPlugin - GPU driver:        4.6.0 NVIDIA 595.45.04
Couldn't load pipewire-0.3 library
Couldn't resolve pipewire-0.3 symbols
qrc:/qt/qml/org/kde/kwin/overview/qml/Main.qml:851:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { ... }
Could not delete render time query because no context is current
NVRM: GPU at PCI:0000:01:00: GPU-7a76a6cd-4e4f-b8ed-d4dd-a9ce713e63f6
NVRM: Xid (PCI:0000:01:00): 79, GPU has fallen off the bus.
NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
NVRM: A GPU crash dump has been created. If possible, please run
NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (GPU Reset Required)
WARNING: CPU: 7 PID: 11252 at nvidia/nv.c:5173 nvidia_dev_put+0xbe/0xd0 [nvidia]
Modules linked in: vxlan ip6_udp_tunnel udp_tunnel nft_log nft_limit ipt_REJECT nf_reject_ipv4 xt_limit xt_NFLOG nfnetlink_log xt_physdev xt_multiport xt_mark xt_nfacct nfnetlink_acct xt_comment qrtr nf_conntrack_netlink xt_tcpudp xt_conntrack xt_MASQUERADE xfrm_user xfrm_algo xt_set ip_set nft_chain_nat xt_addrtype nft_compat nf_tables nfnetlink overlay rfcomm snd_seq_dummy snd_hrtimer snd_seq af_packet uhid cmac algif_hash algif_skcipher af_alg bnep sch_fq_codel btusb btrtl btintel btmtk btbcm snd_usb_audio bluetooth snd_ump snd_usbmidi_lib snd_rawmidi mousedev snd_seq_device input_leds mc ecdh_generic ecc joydev nvidia_drm(PO) nvidia_modeset(PO) nvidia_uvm(PO) nvidia(PO) nls_iso8859_1 nls_cp437 vfat fat snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel snd_sof_intel_hda_sdw_bpt snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda soundwire_cadence snd_sof_pci snd_sof_xtensa_dsp iwlmvm snd_sof snd_hda_codec_alc882 snd_sof_utils snd_soc_acpi_intel_match
[drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device DP-0.
nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-0
nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device DP-2.
nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-2
Applying output configuration failed!
I also setup kde connect to be able to trigger a sudo systemctl restart display-manager without needing a sudoers password. It works typically, but not after all three monitors freeze. I will try running that again for this particular case when only one monitor is frozen to see how different or similar these issues are (the case where all 3 or just 1 monitor freezes).
Since I’ve had the issue of all 3 monitors freezing I’ve tried making the following changes to the configuration of my operating system. The current configuration will also be included but here are the current settings that still freeze either all 3 monitors or just the 1 monitor:
	boot.kernelParams = [ "preempt=full" "pcie_aspm.policy=performance" "nvidia-drm.fbdev=1" "nvidia.NVreg_PreserveVideoMemoryAllocations=1"];
        hardware.nvidia-container-toolkit.enable = true;
        hardware.nvidia = {
                # Modesetting is required.
                modesetting.enable = true;
                # Nvidia power management. Experimental, and can cause sleep/suspend to fail.
                powerManagement.enable = true;
                # Fine-grained power management. Turns off GPU when not in use.
                # Experimental and only works on modern Nvidia GPUs (Turing or newer).
                powerManagement.finegrained = false;
                open = false;
                package = config.boot.kernelPackages.nvidiaPackages.beta;
                nvidiaSettings = true;
I have also tried setting “nvidia.NVreg_EnableGpuFirmware=0” in my kernelParams to no avail. I have had all 3 monitors freeze with open drivers or with proprietary over the last year or more, with powerMangement enabled or disabled. With lts or unstable linux kernel or with alternative kernels like cachy, xanmod, etc.., I would suspect it’s a hardware issue, but it doesn’t seem to happen on windows.
some output from sudo dmesg
[  462.490512] /proc/cgroups lists only v1 controllers, use cgroup.controllers of root cgroup for v2 info
[  559.637719] hrtimer: interrupt took 807397640 ns
[  559.652689] NVRM: GPU at PCI:0000:01:00: GPU-7a76a6cd-4e4f-b8ed-d4dd-a9ce713e63f6
[  559.652700] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000005 00000000 00000000 00000001 00000000
[  560.617930] NVRM: Xid (PCI:0000:01:00): 32, pid=9043, name=AWT-EventQueue-, channel 0x00000013 intr 00008000
[  560.619296] NVRM: Xid (PCI:0000:01:00): 32, pid=9043, name=AWT-EventQueue-, channel 0x00000013 intr 00008000
[  581.335567] NVRM: Xid (PCI:0000:01:00): 69, pid=9043, name=AWT-EventQueue-, Class Error: channel 0x00000013, Class 0000902d, Offset 0000023c, Data 00000000, ErrorCode 00000004
[  586.858091] NVRM: Xid (PCI:0000:01:00): 69, pid=9043, name=AWT-EventQueue-, Class Error: channel 0x00000013, Class 0000902d, Offset 0000023c, Data 00000000, ErrorCode 00000004
more_jctl_outputs_from_multi_monitor_freezes.txt (99.2 KB)
dmesg.txt (87.9 KB)
plasma-kwin_wayland_jctl.txt (1.5 MB)
jctl_logs_from_1248.txt (6.5 KB)
nvidia-bug-report.log.gz (572.7 KB)
The system clock is frozen at Wednesday, September 9, 2026 12:48:41 PM. These are the current logs around that time, but these logs are for the single monitor being frozen, not for all 3 monitors crashing which is more common (so far)
Sep 09 12:48:42 nixos kernel: hrtimer: interrupt took 807397640 ns
Sep 09 12:48:42 nixos kernel: NVRM: GPU at PCI:0000:01:00: GPU-7a76a6cd-4e4f-b8ed-d4dd-a9ce713e63f6
Sep 09 12:48:42 nixos kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000005 00000000 00000000 00000001 00000000
Sep 09 12:48:43 nixos kernel: NVRM: Xid (PCI:0000:01:00): 32, pid=9043, name=AWT-EventQueue-, channel 0x00000013 intr 00008000
Sep 09 12:48:43 nixos kwin_wayland[4711]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Sep 09 12:48:43 nixos kwin_wayland[4711]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Sep 09 12:48:43 nixos kwin_wayland[4711]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Sep 09 12:48:44 nixos kwin_wayland[4711]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Sep 09 12:48:44 nixos kwin_wayland[4711]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Sep 09 12:48:44 nixos kwin_wayland[4711]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
