I want to display a scene in a QGLWidget. My application has only 3 QSlider for the rotation around the X,Y,Z axis and the widget.
I am overriding initializeGL(), paintGL() and resizeGL().
For my understanding, paintGL() gets called everytime when updateGL() is called by my QSlider or Mouseevents. Then I initialize a rotation matrix and apply this matrix to the PinholeCamera in order to trace the scene with new transformed cameracoordinates, right?
For zooming out I use something like
m_camera->dolly(3.5)
When the tracing is finished i get the outputbuffer and use it draw the pixels, just like in GLUTdisplay.cpp
But my problem is that the image is skewed/distorted. For example I wanted to display a ball, but the ball is extremley flatened. Using the given GLUTdisplay, everything works fine.
When I am zooming out, it seems that the Image scales much slower horizontally than vertically.
Here is my initializeGL() method:
void MyGLWidget::initializeGL()
glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
m_scene = new MeshViewer();
m_scene->setMesh( (std::string( sutilSamplesDir() ) + "/ball.obj").c_str() );
int buffer_width, buffer_height;
try {
// Set up scene
SampleScene::InitialCameraData initial_camera_data;
m_scene->setUseVBOBuffer( false );
m_scene->initScene( initial_camera_data );
int m_initial_window_width = 400;
int m_initial_window_height = 400;
if( m_initial_window_width > 0 && m_initial_window_height > 0)
m_scene->resize( m_initial_window_width, m_initial_window_height );
// Initialize camera according to scene params
m_camera = new PinholeCamera( initial_camera_data.eye,
initial_camera_data.lookat,
initial_camera_data.up,
-1.0f, // hfov is ignored when using keep vertical
initial_camera_data.vfov,
PinholeCamera::KeepVertical );
Buffer buffer = m_scene->getOutputBuffer();
RTsize buffer_width_rts, buffer_height_rts;
buffer->getSize( buffer_width_rts, buffer_height_rts );
buffer_width = static_cast<int>(buffer_width_rts);
buffer_height = static_cast<int>(buffer_height_rts);
float3 eye, U, V, W;
m_camera->getEyeUVW( eye, U, V, W );
SampleScene::RayGenCameraData camera_data( eye, U, V, W );
// Initial compilation
m_scene->getContext()->compile();
// Accel build
m_scene->trace( camera_data );
m_scene->getContext()->launch( 0, 0 );
// Initialize state
glMatrixMode(GL_PROJECTION);glLoadIdentity();glOrtho(0, 1, 0, 1, -1, 1 );
glMatrixMode(GL_MODELVIEW); glLoadIdentity(); glViewport(0, 0, buffer_width, buffer_height);
Here is my paintGL() method:
void MyGLWidget::paintGL()
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glLoadIdentity();
try{
nvtx::ScopedRange r( "trace" );
// Draw the resulting image
int buffer_width = static_cast<int>(buffer_width_rts);
int buffer_height = static_cast<int>(buffer_height_rts);
RTformat buffer_format = buffer.get()->getFormat();
GLvoid* imageData = buffer->map();
assert( imageData );
GLenum gl_data_type = GL_FALSE;
GLenum gl_format = GL_FALSE;
switch (buffer_format) {
/*... set gl_data_type and gl_format ...*/
RTsize elementSize = buffer->getElementSize();
int align = 1;
if ((elementSize % 8) == 0) align = 8;
else if ((elementSize % 4) == 0) align = 4;
else if ((elementSize % 2) == 0) align = 2;
glPixelStorei(GL_UNPACK_ALIGNMENT, align);
gldata = QGLWidget::convertToGLFormat(image_data);
NVTX_RangePushA("glDrawPixels");
glDrawPixels( static_cast<GLsizei>( buffer_width ), static_cast<GLsizei>( buffer_height ),gl_format, gl_data_type, imageData);
// glDraw
NVTX_RangePop();
buffer->unmap();
} catch( Exception& e ){
sutilReportError( e.getErrorString().c_str() );
exit(2);
What am I missing? Can someone help me out?
