**• Hardware Platform (Jetson / GPU)**Orin
• DeepStream Version7.1
**• JetPack Version (valid for Jetson only)**6.1
The following code displays only one line on the first image.
I have four sources in display screen like
tiled-display:
enable: 1
rows: 2
columns: 2
width: 1280
height: 720
gpu-id: 0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type: 0
But the polygon is displayed on the first image.
How can I make polygon is drawn on all images?
static GstPadProbeReturn
osd_sink_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *)info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
gboolean is_first_object = TRUE;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
int p_cnt = 0;
int start_x = 50;
int start_y = 50;
for(int p=0; p < 20; p++){
NvOSD_LineParams *line_params = &display_meta->line_params[p];
if(p == 0){
line_params->x1 = start_x;
line_params->y1 = start_y;
}else{
start_x+=10;
start_y+=10;
line_params->y1 = start_x;
line_params->x2 = start_x+10;
line_params->y2 = start_y+10;
line_params->line_width = 2;
line_params->line_color.red = 0.0;
line_params->line_color.green = 0.0;
line_params->line_color.blue = 1.0;
line_params->line_color.alpha = 1.0;
p_cnt++;
display_meta->num_lines = p_cnt;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
frame_number++;
return GST_PAD_PROBE_OK;
