Hello
i was change sor1 HDMI to DP
using DTB file and flash.sh
but when i connect the HDMI to the Dev.kit
it output nvidia logo on the monitor
is this correct???
Hello
is this correct???
Try with full flash and the logo shall be gone.
If you only flash the dtb by “-r -k kernel-dtb”, then the bootloader dtb will not be updated because that command only flash the kernel dtb partition.
Bootloader and kernel read the dtb from different partition.
