Display port not working " current input timing is not supported by the monitor display "
Hi team,
I have an Jetson AGX Orin 64gb dev kit.
Actually i was checking for the different power modes, i was using Mode 30W, which is by default, wanted to check with the Mode 50W there were few red color cross icons, so , i switched back to Mode 30W. On rebooting with the process, am not able to get the display.
Am using dell monitor, in the monitor am seeing
" The current input timing is not supported by the monitor display. Please change your input timing to 1920x1080, 60hz or any. other monitor listed timing as per the monitor specifications." connected diff monitor to check, same issue
I restarted the system and am seeing the boot log. and am getting this msg when ui has to load. But able to connect with ssh.
Is that anything happed with display driver while trying to switch modes. Any help in this would be helpful.
Thanks and Regards
Bggopal
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Hi @carolyuu
i tried your away, i used sdkmanager to reflash the device with new image. But after os creation, while trying to flash am getting error.
i am running on host : 20.04 ubuntu, and trying with jetpack 5.1.2
what might be the issue any insigths.
thanks and Regards
Bggopal
Click the export logs button in the sdkmanager GUI and attach full file here
@WayneWWW
Thanks Wanyne, it was the borken package with download on jetpack 5.1.2. Later switched to 5.1.4 and fixed it .
