Display port not working of jetson nano
I was using my kit, and everything was working fine, including the display. However, after I disconnected the display port, it stopped working and now it’s showing no display.
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Not sure what does this mean, was it unplung than plug-in while device is working?
Have you reboot your device again or reflash your device with newer JetPack SW?
Any log?
it happened after unplugged after turning it off. i did reflash it but it did not work
You should re-flash with SDK Manager, not just the SD card image.
