I am tracking some memory leaks in our application. Unfortunately I am not actually very familiar with the deepstream SDK and the documentation I have found seems quite thin,
Is it documented anywhere who is supposed to free NvOSD_TextParams display_text for NvDsDisplayMeta objects from the nvds_acquire_display_meta_from_pool?
I see in every sample app strings get allocated from the heap and assigned to display_text. They do not seem to get freed.
An example is here:
sources/apps/sample_apps/deepstream-nvdsanalytics-test/deepstream_app_main.c (look at overlay_graphics)
But notice that font_name in the same function is not from the heap.
This is very confusing. And if it is true that display_text is freed when the NvDsDisplayMeta object is recycled I find this to be a particularly terrible implementation. And if not then do all these samples leak memory?
Freeing objects should be the responsibility of the the allocator not transferred. What if I want to allocate all my strings from a pool instead of thrashing the heap?
• Hardware Platform: Jetson Nano
• DeepStream Version: 5.0.1
• JetPack Version: 4.4
