I solved this problem.
This task has two parts:
- Displaying video from some Gstreamer pipline in a Qt window
- Transfer video from jetson-inference to Gstreamer external pipeline
Solution:
This code plays a test Gstreamer video (videotestsrc) in a 640x480 window.
import sys from threading import Thread from PyQt5.QtCore import * from PyQt5.QtGui import * from PyQt5.QtWidgets import * import jetson.utils import gi gi.require_version('Gst', '1.0') gi.require_version('GstVideo', '1.0') from gi.repository import Gst, GObject, GstVideo GObject.threads_init() Gst.init(None) class MainWindow(QMainWindow): def __init__(self): QMainWindow.__init__(self) self.setAttribute(Qt.WA_AcceptTouchEvents, True) self.setGeometry(0,0,640,480) self.videowidget = VideoWidget(parent=self) class VideoWidget(QWidget): def __init__(self, parent): QMainWindow.__init__(self, parent) self.windowId = self.winId() self.setGeometry(0,0,640,480) def setup_pipeline(self): self.pipeline = Gst.Pipeline() self.pipeline = "videotestsrc ! video/x-raw,width=640,height=480 ! videoconvert ! xvimagesink" self.pipeline = Gst.parse_launch(self.pipeline) bus = self.pipeline.get_bus() bus.add_signal_watch() bus.enable_sync_message_emission() bus.connect('sync-message::element', self.on_sync_message) def on_sync_message(self, bus, msg): message_name = msg.get_structure().get_name() print(message_name) if message_name == 'prepare-window-handle': win_id = self.windowId assert win_id imagesink = msg.src imagesink.set_window_handle(win_id) def start_pipeline(self): self.pipeline.set_state(Gst.State.PLAYING) app = QApplication([]) window = MainWindow() window.videowidget.setup_pipeline() window.videowidget.start_pipeline() window.show() sys.exit(app.exec_())
2.1 In order to link two pipelines in one program, it is possible to use the intervideosink/intervideosrc Gstreamer module (maybe also udpsink/udpsrc, but I didn’t check it). As far as I understand, image transmission using intervideosink/intervideosrc does not require additional resources for encoding/decoding, unlike udp or rtsp.
Accordingly, the pipeline in the previous example should be like this:
intervideosrc channel=v0 ! xvimagesink
Pay attention to the parameter “channel”, it allows you to connect a certain pair of pipelines and can contain letters and numbers.
2.2. In turn, jetson-inference should create an output pipeline with intervideosink module. But the original version jetson-inference has the following output streams: RTP stream, Video file, Image file, Image sequence OpenGL window.
I modified the source code and added another type, “intervideo://0”, which creates a pipeline with intervideosink.
Video output looks like this:
jetson.utils.videoOutput('intervideo://0', argv=['--headless'])
