Displaying using VBO
Hi I have something that I cannot understand how it works that much. So SDK called SimpleGL somehow uses extern “C” to wrap kernel
function to compile in C style but Im not sure how they can use values in host directly when calling kernel function. Bellow is the code.
 * Copyright 1993-2010 NVIDIA Corporation.  All rights reserved.
 * Please refer to the NVIDIA end user license agreement (EULA) associated
 * with this source code for terms and conditions that govern your use of
 * this software. Any use, reproduction, disclosure, or distribution of
 * this software and related documentation outside the terms of the EULA
 * is strictly prohibited.
/* This example demonstrates how to use the Cuda OpenGL bindings with the
  * runtime API.
  * Device code.
#ifndef _SIMPLEGL_KERNEL_H_
#define _SIMPLEGL_KERNEL_H_
//! Simple kernel to modify vertex positions in sine wave pattern
//! @param data  data in global memory
__global__ void kernel(float4* pos, unsigned int width, unsigned int height, float time)
    unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
    unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
// calculate uv coordinates
    float u = x / (float) width;
    float v = y / (float) height;
    u = u*2.0f - 1.0f;
    v = v*2.0f - 1.0f;
// calculate simple sine wave pattern
    float freq = 4.0f;
    float w = sinf(u*freq + time) * cosf(v*freq + time) * 0.5f;
// write output vertex
    pos[y*width+x] = make_float4(u, w, v, 1.0f);
// Wrapper for the __global__ call that sets up the kernel call
extern "C" void launch_kernel(float4* pos, unsigned int mesh_width, unsigned int mesh_height, float time)
    // execute the kernel
    dim3 block(8, 8, 1);
    dim3 grid(mesh_width / block.x, mesh_height / block.y, 1);
    kernel<<< grid, block>>>(pos, mesh_width, mesh_height, time);
#endif // #ifndef _SIMPLEGL_KERNEL_H_
does anybody know how this works? Is there case when I can directly use host memory instead of sending values to GPU using
cudaMemcpy and cudaMalloc? Thank you.
Regard,
Masterkiten
[font=“Courier New”]launch_kernel()[/font] is called with a device pointer as first argument. Declaring it as C linking style doesn’t prevent that.
