Displaymode Selector Firmware older than Factory
I’ve got some 6000 Ada cards that I can’t switch to compute mode. Two cards in the system, one works, one doesn’t, they appear to have different firmware levels.
Is it possible to get an updated displaymodeselector tool with current firmware images?
Below GPU 0 changed to compute using --gpumode compute --auto
GPU 1 errored with:
Reading EEPROM (this operation may take up to 30 seconds)
Apply GPU Mode <4> corresponds to "physical_display_disabled"
Provided version is older than factory version 95.02.59.00.09
ERROR: Downgrading to a version older than the factory version is not allowed.```
root@----------:~# ./displaymodeselector --version
NVIDIA Display Mode Selector Utility (Version 1.67.0)
Copyright (C) 2015-2021, NVIDIA Corporation. All Rights Reserved.
BIOS Versions of NVIDIA display adapters present in system:
<0> Graphics Device      (10DE,26B1,10DE,16A1) S:00,B:C1,D:00,F:00 95.02.3A.00.01
    InfoROM Version    : G133.0510.00.01
    XUSB-FW Version ID : N/A
<1> Graphics Device      (10DE,26B1,1028,16A1) S:00,B:E1,D:00,F:00 95.02.59.00.08
    InfoROM Version    : G133.0510.00.02
When did you download the modeselector tool?
4/5 days ago.
Version 1.67 date modified 5/13/2024
So it’s the latest one. Where did you buy the GPU? I would try to replace it
Is that the only option? I have 20x GPU’s in a Evaluation setup looking at vGPU’s for render farms and remote access.
Yes, ADA 6000 is a workststion GPU and not meant for DC usage. Therefore the default mode is not DC. This is different for L40S which is almost the same GPU but for DC usage and there you don’t need to change mode for vGPU usage.
I’m confused.
The documentation very clearly states that the 6000 ada is capable of being used for vgpu tasks.
I have a number of cards working well. The issue is that the display mode selector does not have an up to date firmware to work with current cards.
Is the documentation wrong?
For sure it is working and supported for vGPU, but as I said the primary use case is different. Therefore you need to accept the obstacle to use the mode selector tool.
And as you seem to have bought vGPU licenses, please open a support ticket and address the issue with the selector tool with our Enterprise Support
I’m very confused by this.
The headline on the Display Mode Selector tool reads:
NVIDIA Display Mode Selector Tool
The NVIDIA Display Mode Selector Tool is a utility to set the desired display mode for NVIDIA L40S, NVIDIA L40, NVIDIA RTX 6000 Ada, NVIDIA A40, NVIDIA RTX A5000, NVIDIA RTX A5500, and NVIDIA RTX A6000 GPUs. Changing the display mode is supported for specific use cases, including CAVES, Virtual Production, and Location-based Entertainment.
It is specifically designed to switch GPU with output ports into vGPU capable cards listed in that statement.
Is therefore not a reasonable request to expect the tool to support current vbios versions that would exist on the cards that the tool is designed to use?
I’m currently using an evaluation license, so do not have access to support, but can’t evaluate because I need access to support to help get the tools working!
Hi, I had the same problem, how did you solve it?
root@pve8:~# ./displaymodeselector --gpumode compute --auto
WARNING: This operation updates the firmware on the board and could make
         the device unusable if your host system lacks the necessary support.
Specifed GPU Mode "physical_display_disabled"
root@pve8:~# ./displaymodeselector --version
Redundant Firmware    : Instance 0 (Identical)
Sign-On Message       : PG133 SKU 510 VGA BIOS
Build GUID            : *******
Build Number          : ********
IFR Subsystem ID      : 1028-16A1
Subsystem Vendor ID   : 0x1028
Subsystem ID          : 0x16A1
Version               : 95.02.59.00.08
Image Hash            : N/A
Product Name          : GPU Board
Device Name(s)        : Graphics Device
Board ID              : 0x0430
Vendor ID             : 0x10DE
Device ID             : 0x26B1
Hierarchy ID          : Normal Board
Chip SKU              : 870-0
Project               : G133-0510
Build Date            : 04/12/23
Modification Date     : 05/03/23
UEFI Version          : 0x7000E ( x64 )
UEFI Variant ID       : 0x000000000000000B ( Unknown )
UEFI Signer(s)        : Microsoft Corporation UEFI CA 2011
XUSB-FW Build Time    : N/A
InfoROM Backup        : Present
License Placeholder   : Present
GPU Mode              : Graphics
CEC OTA-signed Blob   : Not Present
root@pve8:~# lspci | grep NVIDIA
a1:00.0 VGA compatible controller: NVIDIA Corporation AD102GL [L6000 / RTX 6000 Ada Generation] (rev a1)
a1:00.1 Audio device: NVIDIA Corporation AD102 High Definition Audio Controller (rev a1)
