I configured a dual monitor with displayport and Hdmi on Tx2. Dp0 is configured as displayport, DP1 as hdmi.
The dts in the displayport forum were used to create and run the sub-board on the display connector (J23) of the EVM board.
Video operation is normal. However, the OS does not recognize the audio as a device.
Can anyone help me? Thanks a lot.
Hello!
For test purposes can you try …
$ speaker-test -D hw:tegrahda,3 -c 2 -r 48000 -F S16_LE -t sine -f 500
This should play a tone on left and right channels. You can vary the number of channels as needed by setting the ‘-c’ option.
If this is working fine, then if you want to select this audio interface as the default interface can you add the following to the file /usr/share/alsa/cards/tegra-hda.conf …
tegra-hda.pcm.hdmi.0 {
@args [ CARD AES0 AES1 AES2 AES3 ]
@args.CARD { type string }
@args.AES0 { type integer }
@args.AES1 { type integer }
@args.AES2 { type integer }
@args.AES3 { type integer }
type hooks
slave.pcm {
type hw
card $CARD
device 3
hint.device 3
Note you will need to restart pulseaudio or reboot after making the above change. You can restart pulseaudio by …
$ pulseaudio -k
Regards,
Jon
It works fine.
Thank you.
