I have single T1000 card on Ubuntu system and want to start four separate 4K screens at 60 Hz each. I use nvidia-settings for configuring X layout. By default nvidia-settings put all monitors into one screen and that mode work as supposed - I can specify 3840x2160@60Hz for each monitor and after saving configuration and restarting X system all is set as supposed (similar picture for each monitor):
But then I tried to create 4 separate screens with same 3840x2160@60Hz parameters X not started with following complain:
20161 [ 8597.616] (II) NVIDIA(0): Screen initialization complete
20162 [ 8597.618] (II) NVIDIA(1): kernel module enabled successfully
20163 [ 8597.618] (II) NVIDIA(1): GPU initialized
20164 [ 8597.620] (==) NVIDIA(1): Using 8388608 bytes for software rendering cache
20165 [ 8597.650] (II) NVIDIA(1): Setting mode "DP-0:3840x2160_60+0+0{AllowGSYNC=Off}"
20166 [ 8597.685] (WW) NVIDIA(1): Failed to set the display configuration
20167 [ 8597.685] (WW) NVIDIA(1): - Setting a mode on display 0 failed: There was insufficient
20168 [ 8597.685] (WW) NVIDIA(1): available DisplayPort bandwidth
20169 [ 8597.685] (EE)
20170 Fatal server error:
20171 [ 8597.685] (EE) AddScreen/ScreenInit failed for driver 1
20172 [ 8597.685] (EE)
20173 [ 8597.685] (EE)
It failed on initialization of second screen.
Specification of T1000 says it support 4x 4K @120Hz
I can’t understood why this problem is happened.
My four monitors currently are plugs (all the same) with following parameters :
EDID Name : XMD Mi TV
Minimum HorizSync : 15.000 kHz
Maximum HorizSync : 140.000 kHz
Minimum VertRefresh : 49 Hz
Maximum VertRefresh : 80 Hz
Maximum PixelClock : 600.000 MHz
Maximum Width : 4096 pixels
Maximum Height : 2160 pixels
Preferred Width : 1920 pixels
Preferred Height : 1080 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 600 mm
Physical Height : 340 mm
(I tried different configurations with 2 and 3 cards, but returned to testing configuration with single card, hope someone can recognize what is the problem here).
Need to state that use of 1920x1080 resolutions or 30Hz refresh rates allow X system to start. The problem appeared when 4K@60Hz is used.
nvidia-bug-report.log.gz (1.2 MB)
