what is minimum and maximum distance for LI-IMX219-MIPI-FF-NANO MIPI CSI-2 Camera object detection?
@WayneWWW @JerryChang @Fiona.Chen
Thanks,
Chaithra
Thanks,
Chaithra
did you meant the effect distance between camera and target?
what’s the real use-case, may I know which algorithm you’re used for evaluation?
I am using Jetson Xavier-NX dekit with CSI Camera Connected.
I am using the jetson inference model to detect the object
what is the maximum distance would camera can detect the object in LI-IMX219-MIPI-FF-NANO MIPI CSI-2 Camera?
It’s related to the image resolution that feeds into the networks.
Some discussion for you reference:
