Distortion in video encoding
I’ve 4 cameras (640x320480) running on at 25Hz and I put these images together to a panorama image (2560x320480) and then encode these panorama images for a video stream.
When I encode with H264 everything looks fine, with the exception of a few artifacts in the encoded frame every now and then. However, if I use H265 then a good amount of the frames becomes a distorted mess (See image)
Anyone has an idea as to why this happens ?
I’m using a Jetson AGX Orin 32Gb.
Is there a way to replicate it on AGX Orin developer kit? We run the command and the video file is good:
$ gst-launch-1.0 videotestsrc num-buffers=100 ! video/x-raw,width=2560,height=320 ! nvvidconv ! nvv4l2h265enc ! h265parse ! matroskamux ! filesink location=hevc.mkv
Please share an approach to replicate it so that we can check further.
I wrote wrong height in the original post. The resolution should be 2650x480 not 2650x320.
I’ll see if I can find an approach so that you can reproduce the error.
Yes, it’s still an issue. I’ve just haven’t had the time to look into it further unfortunately.
