I wrote a library that wraps cuvid functionality. I made a small C++ demo that uses the lib. It works all fine. No problems at all.
Now, I made a plugin for Unity Engine that uses this lib. And it has some problems. I get no runtime errors, neither from CUDA nor cuvid. But for some unknown reasons the first 6-7 frames I decode are empty. In function HandlePictureDisplay I call all cuvidMapVideoFrame/cuvidGetDecodeStatus/cudaMemcpy/cuvidUnmapVideoFrame and none of these functions return any error. But I start getting any actual data after 6 frames or so. The frist 6-7 frames are either filled with 0’s or 1’s (talking 0-255 range)). This doesn’t happen in my simple C++ demo.
There is actually one more problem. Chroma data is empty. On output I get a very “greenish” image as all chroma values are 1’s (talking 0-255 range).
Could this be the decoder bug? The difference between my demo C++ app and Unity is that well, Unity does a helluva of other things so maybe some render states affect this problem? I could provide source code for inspection if necessary.
