Hello, when I run the following kernel, the CUDA profiler reports that there’s a lot of divergence in the threads, and so my instruction throughput is only 3% of the theoretical max.
where “input” is an array copied from the host to CPU, and has boolean values (0 and 1’s only). The values are fairly random, and there is no way I can organize them to be not random. So my question is, why is this code divergent? I assume the divergence happens at
exGInc[i]*input[i]
because of the random values in “input”. So I’m wondering, why is the codepath divergent for it, and is there a way I can make this non-divergent? Thanks.
There should be no divergence in the code you show. Moreover, the memory coalescing should be perfect on compute capability >=1.2 devices if CUDAGRNUMTHREAD == blockDim.x. (the unsigned char will not read coalesced on compute capability 1.1 and earlier due to memory controller limitations) The random contents of input don’t matter because you are reading them in thread order and just performing a multiplication.
Which profiler counter are you referring to exactly? “divergent_branch”?
