The voltage of dji M210v2 power supply port is DC18~26V and the current is 4A. Can I directly use it to supply power to TX2? Do I need a voltage conversion module? If I need to use which conversion module is better?
The voltage is not regulated and ranges from 18V to 26V with current of 2A
The voltage range of TX2 is 5.5v ~ 19.6v, so it can’t be used to TX2 directly. We have no recommended “conversion module”, you can search in market for some DC/DC module for this.
