DLA cudlaSubmitTask function takes too long (12ms+)
The time taken by the cudlaSubmitTask function varies greatly, when setting the idleTime parameter of trtexec:
nsys profile -t cuda,nvtx,nvmedia \
 --cuda-flush-interval=30000 \
 --accelerator-trace=nvmedia --show-output=true \
 --force-overwrite=true --output=/usr/src/tensorrt/tmp/normal \
 trtexec \
 --loadEngine=example.engine \
 --fp16 --useDLACore=1 --allowGPUFallback
 trtexec \
 --fp16 --useDLACore=1 --allowGPUFallback \
 --idleTime=2000
It can be observed that when idleTime is greater than 500, there will be a trend of increasing time consumption. For example, when idleTime 100 vs 2000, the cudlaSubmitTask time is 80us vs 12ms.
Could you maximize the device’s performance and try it again?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
If the same behavior is observed, please share the log you get with/without --idleTime.
Already in MAXN model, and jetson_clocks is enabled.
case: idleTime=0
case: idleTime=2000
case: idleTime=0
WARNING: --trace=nvmedia is deprecated, use tegra-accelerators in the future.
WARNING: Deprecated --accelerator-trace argument: nvmedia.
Value 'tegra-accelerators' should be used in the future.
&&&& RUNNING TensorRT.trtexec [TensorRT v8502] # /usr/bin/trtexec --loadEngine=example.engine --plugins=/usr/src/tensorrt/libplugin.so --fp16 --useDLACore=1 --allowGPUFallback
[03/27/2024-11:27:18] [I] === Model Options ===
[03/27/2024-11:27:18] [I] Format: *
[03/27/2024-11:27:18] [I] Model:
[03/27/2024-11:27:18] [I] Output:
[03/27/2024-11:27:18] [I] === Build Options ===
[03/27/2024-11:27:18] [I] Max batch: 1
[03/27/2024-11:27:18] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[03/27/2024-11:27:18] [I] minTiming: 1
[03/27/2024-11:27:18] [I] avgTiming: 8
[03/27/2024-11:27:18] [I] Precision: FP32+FP16
[03/27/2024-11:27:18] [I] LayerPrecisions:
[03/27/2024-11:27:18] [I] Calibration:
[03/27/2024-11:27:18] [I] Refit: Disabled
[03/27/2024-11:27:18] [I] Sparsity: Disabled
[03/27/2024-11:27:18] [I] Safe mode: Disabled
[03/27/2024-11:27:18] [I] DirectIO mode: Disabled
[03/27/2024-11:27:18] [I] Restricted mode: Disabled
[03/27/2024-11:27:18] [I] Build only: Disabled
[03/27/2024-11:27:18] [I] Save engine:
[03/27/2024-11:27:18] [I] Load engine: example.engine
[03/27/2024-11:27:18] [I] Profiling verbosity: 0
[03/27/2024-11:27:18] [I] Tactic sources: Using default tactic sources
[03/27/2024-11:27:18] [I] timingCacheMode: local
[03/27/2024-11:27:18] [I] timingCacheFile:
[03/27/2024-11:27:18] [I] Heuristic: Disabled
[03/27/2024-11:27:18] [I] Preview Features: Use default preview flags.
[03/27/2024-11:27:18] [I] Input(s)s format: fp32:CHW
[03/27/2024-11:27:18] [I] Output(s)s format: fp32:CHW
[03/27/2024-11:27:18] [I] Input build shapes: model
[03/27/2024-11:27:18] [I] Input calibration shapes: model
[03/27/2024-11:27:18] [I] === System Options ===
[03/27/2024-11:27:18] [I] Device: 0
[03/27/2024-11:27:18] [I] DLACore: 1(With GPU fallback)
[03/27/2024-11:27:18] [I] Plugins: /usr/src/tensorrt/libplugin.so
[03/27/2024-11:27:18] [I] === Inference Options ===
[03/27/2024-11:27:18] [I] Batch: 1
[03/27/2024-11:27:18] [I] Input inference shapes: model
[03/27/2024-11:27:18] [I] Iterations: 10
[03/27/2024-11:27:18] [I] Duration: 3s (+ 200ms warm up)
[03/27/2024-11:27:18] [I] Sleep time: 0ms
[03/27/2024-11:27:18] [I] Idle time: 0ms
[03/27/2024-11:27:18] [I] Streams: 1
[03/27/2024-11:27:18] [I] ExposeDMA: Disabled
[03/27/2024-11:27:18] [I] Data transfers: Enabled
[03/27/2024-11:27:18] [I] Spin-wait: Disabled
[03/27/2024-11:27:18] [I] Multithreading: Disabled
[03/27/2024-11:27:18] [I] CUDA Graph: Disabled
[03/27/2024-11:27:18] [I] Separate profiling: Disabled
[03/27/2024-11:27:18] [I] Time Deserialize: Disabled
[03/27/2024-11:27:18] [I] Time Refit: Disabled
[03/27/2024-11:27:18] [I] NVTX verbosity: 0
[03/27/2024-11:27:18] [I] Persistent Cache Ratio: 0
[03/27/2024-11:27:18] [I] Inputs:
[03/27/2024-11:27:18] [I] === Reporting Options ===
[03/27/2024-11:27:18] [I] Verbose: Disabled
[03/27/2024-11:27:18] [I] Averages: 10 inferences
[03/27/2024-11:27:18] [I] Percentiles: 90,95,99
[03/27/2024-11:27:18] [I] Dump refittable layers:Disabled
[03/27/2024-11:27:18] [I] Dump output: Disabled
[03/27/2024-11:27:18] [I] Profile: Disabled
[03/27/2024-11:27:18] [I] Export timing to JSON file:
[03/27/2024-11:27:18] [I] Export output to JSON file:
[03/27/2024-11:27:18] [I] Export profile to JSON file:
[03/27/2024-11:27:18] [I] === Device Information ===
[03/27/2024-11:27:18] [I] Selected Device: Orin
[03/27/2024-11:27:18] [I] Compute Capability: 8.7
[03/27/2024-11:27:18] [I] SMs: 16
[03/27/2024-11:27:18] [I] Compute Clock Rate: 1.3 GHz
[03/27/2024-11:27:18] [I] Device Global Memory: 62800 MiB
[03/27/2024-11:27:18] [I] Shared Memory per SM: 164 KiB
[03/27/2024-11:27:18] [I] Memory Bus Width: 256 bits (ECC disabled)
[03/27/2024-11:27:18] [I] Memory Clock Rate: 1.3 GHz
[03/27/2024-11:27:18] [I] TensorRT version: 8.5.2
[03/27/2024-11:27:18] [I] Loading supplied plugin library: /usr/src/tensorrt/libplugin.so
[03/27/2024-11:27:18] [I] Engine loaded in 0.00136703 sec.
[03/27/2024-11:27:19] [I] [TRT] Loaded engine size: 1 MiB
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +954, GPU +905, now: CPU 1424, GPU 19035 (MiB)
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +130, GPU +121, now: CPU 1554, GPU 19156 (MiB)
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +1, GPU +0, now: CPU 1, GPU 0 (MiB)
[03/27/2024-11:27:20] [I] Engine deserialized in 1.61347 sec.
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1554, GPU 19156 (MiB)
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 1554, GPU 19156 (MiB)
[03/27/2024-11:27:20] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +2, now: CPU 1, GPU 2 (MiB)
[03/27/2024-11:27:20] [I] Setting persistentCacheLimit to 0 bytes.
[03/27/2024-11:27:20] [I] Using random values for input input.1
[03/27/2024-11:27:20] [I] Created input binding for input.1 with dimensions 1x540x960x3
[03/27/2024-11:27:20] [I] Using random values for output weather
[03/27/2024-11:27:20] [I] Created output binding for weather with dimensions 1x5
[03/27/2024-11:27:20] [I] Using random values for output light
[03/27/2024-11:27:20] [I] Created output binding for light with dimensions 1x3
[03/27/2024-11:27:20] [I] Using random values for output scene
[03/27/2024-11:27:20] [I] Created output binding for scene with dimensions 1x3
[03/27/2024-11:27:20] [I] Using random values for output road
[03/27/2024-11:27:20] [I] Created output binding for road with dimensions 1x5
[03/27/2024-11:27:20] [I] Starting inference
[03/27/2024-11:27:23] [I] Warmup completed 105 queries over 200 ms
[03/27/2024-11:27:23] [I] Timing trace has 2036 queries over 3.00307 s
[03/27/2024-11:27:23] [I] === Trace details ===
[03/27/2024-11:27:23] [I] Trace averages of 10 runs:
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45706 ms - Host latency: 1.66639 ms (enqueue 0.47675 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45776 ms - Host latency: 1.66772 ms (enqueue 0.466039 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45652 ms - Host latency: 1.66585 ms (enqueue 0.466191 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45803 ms - Host latency: 1.66949 ms (enqueue 0.481042 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4561 ms - Host latency: 1.66429 ms (enqueue 0.469135 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45657 ms - Host latency: 1.66697 ms (enqueue 0.486496 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45768 ms - Host latency: 1.66899 ms (enqueue 0.486575 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45733 ms - Host latency: 1.66782 ms (enqueue 0.488028 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45942 ms - Host latency: 1.67298 ms (enqueue 0.504929 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46137 ms - Host latency: 1.67337 ms (enqueue 0.485886 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45649 ms - Host latency: 1.66755 ms (enqueue 0.487012 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46046 ms - Host latency: 1.67445 ms (enqueue 0.498984 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45723 ms - Host latency: 1.66705 ms (enqueue 0.4802 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45939 ms - Host latency: 1.67005 ms (enqueue 0.485437 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45798 ms - Host latency: 1.66714 ms (enqueue 0.481595 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45874 ms - Host latency: 1.66895 ms (enqueue 0.468042 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45668 ms - Host latency: 1.66455 ms (enqueue 0.471426 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45996 ms - Host latency: 1.66993 ms (enqueue 0.484088 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45968 ms - Host latency: 1.67003 ms (enqueue 0.501218 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46142 ms - Host latency: 1.67396 ms (enqueue 0.496765 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.56406 ms - Host latency: 1.77726 ms (enqueue 0.501459 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.82438 ms - Host latency: 2.04652 ms (enqueue 0.63291 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.59962 ms - Host latency: 1.81921 ms (enqueue 0.531757 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45901 ms - Host latency: 1.67736 ms (enqueue 0.553259 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46077 ms - Host latency: 1.67183 ms (enqueue 0.485278 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45812 ms - Host latency: 1.66689 ms (enqueue 0.490466 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45506 ms - Host latency: 1.66547 ms (enqueue 0.478394 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46006 ms - Host latency: 1.67153 ms (enqueue 0.521082 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45583 ms - Host latency: 1.66489 ms (enqueue 0.495251 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45727 ms - Host latency: 1.66743 ms (enqueue 0.487988 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45734 ms - Host latency: 1.66744 ms (enqueue 0.481171 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45948 ms - Host latency: 1.67023 ms (enqueue 0.483136 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45713 ms - Host latency: 1.66778 ms (enqueue 0.483295 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45564 ms - Host latency: 1.66667 ms (enqueue 0.484235 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45834 ms - Host latency: 1.66791 ms (enqueue 0.485638 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.47556 ms - Host latency: 1.68592 ms (enqueue 0.489648 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.48019 ms - Host latency: 1.69281 ms (enqueue 0.488275 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45974 ms - Host latency: 1.67141 ms (enqueue 0.494995 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4544 ms - Host latency: 1.66859 ms (enqueue 0.594019 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.458 ms - Host latency: 1.67133 ms (enqueue 0.53092 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46442 ms - Host latency: 1.68181 ms (enqueue 0.583917 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46835 ms - Host latency: 1.68158 ms (enqueue 0.499084 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.47944 ms - Host latency: 1.70254 ms (enqueue 0.591467 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45739 ms - Host latency: 1.67037 ms (enqueue 0.489404 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45323 ms - Host latency: 1.66199 ms (enqueue 0.47699 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.54336 ms - Host latency: 1.754 ms (enqueue 0.473907 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.7148 ms - Host latency: 1.93453 ms (enqueue 0.524701 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.5236 ms - Host latency: 1.73427 ms (enqueue 0.498602 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45869 ms - Host latency: 1.66777 ms (enqueue 0.466077 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45506 ms - Host latency: 1.66352 ms (enqueue 0.48208 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45502 ms - Host latency: 1.66366 ms (enqueue 0.47652 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45558 ms - Host latency: 1.66385 ms (enqueue 0.478119 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45875 ms - Host latency: 1.66883 ms (enqueue 0.474854 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45533 ms - Host latency: 1.66528 ms (enqueue 0.478094 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45394 ms - Host latency: 1.66253 ms (enqueue 0.473767 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45709 ms - Host latency: 1.66808 ms (enqueue 0.47254 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45736 ms - Host latency: 1.66793 ms (enqueue 0.480383 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45654 ms - Host latency: 1.66676 ms (enqueue 0.4755 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45703 ms - Host latency: 1.66835 ms (enqueue 0.478296 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.459 ms - Host latency: 1.66917 ms (enqueue 0.4745 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.63291 ms - Host latency: 1.8491 ms (enqueue 0.511633 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45565 ms - Host latency: 1.66605 ms (enqueue 0.487891 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45441 ms - Host latency: 1.66503 ms (enqueue 0.465417 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45896 ms - Host latency: 1.66953 ms (enqueue 0.488782 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45763 ms - Host latency: 1.66766 ms (enqueue 0.471228 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45824 ms - Host latency: 1.66936 ms (enqueue 0.481482 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45768 ms - Host latency: 1.66804 ms (enqueue 0.473047 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45566 ms - Host latency: 1.66555 ms (enqueue 0.477014 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.452 ms - Host latency: 1.66136 ms (enqueue 0.47052 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45592 ms - Host latency: 1.66499 ms (enqueue 0.47876 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45688 ms - Host latency: 1.665 ms (enqueue 0.469421 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45754 ms - Host latency: 1.66586 ms (enqueue 0.474622 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45774 ms - Host latency: 1.66655 ms (enqueue 0.475293 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45361 ms - Host latency: 1.66295 ms (enqueue 0.467932 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45659 ms - Host latency: 1.66539 ms (enqueue 0.477295 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45902 ms - Host latency: 1.66943 ms (enqueue 0.490906 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45443 ms - Host latency: 1.66179 ms (enqueue 0.475793 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45515 ms - Host latency: 1.66475 ms (enqueue 0.478699 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45426 ms - Host latency: 1.66222 ms (enqueue 0.472131 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46008 ms - Host latency: 1.671 ms (enqueue 0.482166 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4579 ms - Host latency: 1.66593 ms (enqueue 0.472522 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45355 ms - Host latency: 1.66353 ms (enqueue 0.46709 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45862 ms - Host latency: 1.66764 ms (enqueue 0.476929 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45439 ms - Host latency: 1.66353 ms (enqueue 0.463464 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45436 ms - Host latency: 1.66407 ms (enqueue 0.474683 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45669 ms - Host latency: 1.66666 ms (enqueue 0.463672 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45632 ms - Host latency: 1.66394 ms (enqueue 0.468921 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45801 ms - Host latency: 1.66885 ms (enqueue 0.524609 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.76981 ms - Host latency: 1.98521 ms (enqueue 0.557227 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.6629 ms - Host latency: 1.87385 ms (enqueue 0.484692 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.56219 ms - Host latency: 1.77168 ms (enqueue 0.477441 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45667 ms - Host latency: 1.66538 ms (enqueue 0.473987 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45847 ms - Host latency: 1.66862 ms (enqueue 0.464929 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45548 ms - Host latency: 1.66418 ms (enqueue 0.463745 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46462 ms - Host latency: 1.67582 ms (enqueue 0.474634 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45648 ms - Host latency: 1.66547 ms (enqueue 0.476489 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45417 ms - Host latency: 1.66174 ms (enqueue 0.472717 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45558 ms - Host latency: 1.6656 ms (enqueue 0.473364 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45618 ms - Host latency: 1.6647 ms (enqueue 0.471826 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45366 ms - Host latency: 1.66173 ms (enqueue 0.470654 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45596 ms - Host latency: 1.6647 ms (enqueue 0.473462 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45854 ms - Host latency: 1.66739 ms (enqueue 0.472644 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45297 ms - Host latency: 1.66151 ms (enqueue 0.464917 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.49756 ms - Host latency: 1.70978 ms (enqueue 0.474036 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45776 ms - Host latency: 1.66554 ms (enqueue 0.475549 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45088 ms - Host latency: 1.6615 ms (enqueue 0.474377 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45724 ms - Host latency: 1.66624 ms (enqueue 0.490613 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45989 ms - Host latency: 1.67108 ms (enqueue 0.484131 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46218 ms - Host latency: 1.67249 ms (enqueue 0.4677 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46472 ms - Host latency: 1.67485 ms (enqueue 0.468408 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45635 ms - Host latency: 1.66803 ms (enqueue 0.476123 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45375 ms - Host latency: 1.6639 ms (enqueue 0.472083 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45615 ms - Host latency: 1.66486 ms (enqueue 0.465405 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45972 ms - Host latency: 1.66921 ms (enqueue 0.481421 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.62207 ms - Host latency: 1.83123 ms (enqueue 0.471436 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.64185 ms - Host latency: 1.86047 ms (enqueue 0.474023 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.49277 ms - Host latency: 1.70242 ms (enqueue 0.495557 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45742 ms - Host latency: 1.66683 ms (enqueue 0.477576 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45446 ms - Host latency: 1.66201 ms (enqueue 0.473682 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4558 ms - Host latency: 1.66407 ms (enqueue 0.468433 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46182 ms - Host latency: 1.67128 ms (enqueue 0.501709 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45786 ms - Host latency: 1.66842 ms (enqueue 0.496069 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45775 ms - Host latency: 1.66913 ms (enqueue 0.472668 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4589 ms - Host latency: 1.67365 ms (enqueue 0.531397 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4564 ms - Host latency: 1.66946 ms (enqueue 0.485535 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45564 ms - Host latency: 1.66764 ms (enqueue 0.498865 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45657 ms - Host latency: 1.66716 ms (enqueue 0.481299 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45889 ms - Host latency: 1.67002 ms (enqueue 0.495337 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4553 ms - Host latency: 1.66724 ms (enqueue 0.496826 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45786 ms - Host latency: 1.67043 ms (enqueue 0.504858 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4604 ms - Host latency: 1.66895 ms (enqueue 0.473828 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45742 ms - Host latency: 1.67043 ms (enqueue 0.504517 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46152 ms - Host latency: 1.67476 ms (enqueue 0.536597 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45701 ms - Host latency: 1.66807 ms (enqueue 0.489917 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45562 ms - Host latency: 1.66465 ms (enqueue 0.47605 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45811 ms - Host latency: 1.67019 ms (enqueue 0.493066 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45627 ms - Host latency: 1.66541 ms (enqueue 0.497485 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45466 ms - Host latency: 1.66682 ms (enqueue 0.471265 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45408 ms - Host latency: 1.66565 ms (enqueue 0.486035 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45825 ms - Host latency: 1.67256 ms (enqueue 0.502588 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46331 ms - Host latency: 1.67866 ms (enqueue 0.529346 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4623 ms - Host latency: 1.67185 ms (enqueue 0.477759 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46909 ms - Host latency: 1.68564 ms (enqueue 0.536157 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46609 ms - Host latency: 1.68064 ms (enqueue 0.513696 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4571 ms - Host latency: 1.67412 ms (enqueue 0.550146 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46013 ms - Host latency: 1.67385 ms (enqueue 0.519824 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45952 ms - Host latency: 1.66926 ms (enqueue 0.493164 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45923 ms - Host latency: 1.67485 ms (enqueue 0.560913 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4573 ms - Host latency: 1.66802 ms (enqueue 0.483008 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45876 ms - Host latency: 1.6666 ms (enqueue 0.475854 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45359 ms - Host latency: 1.66338 ms (enqueue 0.472754 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46372 ms - Host latency: 1.67756 ms (enqueue 0.500537 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45732 ms - Host latency: 1.66978 ms (enqueue 0.499756 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4572 ms - Host latency: 1.66516 ms (enqueue 0.475513 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4585 ms - Host latency: 1.67014 ms (enqueue 0.465063 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45857 ms - Host latency: 1.67244 ms (enqueue 0.546851 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.74458 ms - Host latency: 1.96262 ms (enqueue 0.476416 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.59404 ms - Host latency: 1.80503 ms (enqueue 0.477295 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.54126 ms - Host latency: 1.75359 ms (enqueue 0.475513 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46367 ms - Host latency: 1.6752 ms (enqueue 0.476343 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46001 ms - Host latency: 1.66965 ms (enqueue 0.465259 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45498 ms - Host latency: 1.66638 ms (enqueue 0.510474 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45784 ms - Host latency: 1.66733 ms (enqueue 0.472217 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45601 ms - Host latency: 1.6656 ms (enqueue 0.467407 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45542 ms - Host latency: 1.66416 ms (enqueue 0.461255 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45645 ms - Host latency: 1.66399 ms (enqueue 0.465625 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4575 ms - Host latency: 1.66516 ms (enqueue 0.464331 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45449 ms - Host latency: 1.6626 ms (enqueue 0.473071 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45593 ms - Host latency: 1.6666 ms (enqueue 0.462793 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46064 ms - Host latency: 1.67078 ms (enqueue 0.470996 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45759 ms - Host latency: 1.66782 ms (enqueue 0.513257 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.49551 ms - Host latency: 1.71338 ms (enqueue 0.522656 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45674 ms - Host latency: 1.6655 ms (enqueue 0.47395 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45381 ms - Host latency: 1.66326 ms (enqueue 0.467383 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45659 ms - Host latency: 1.66633 ms (enqueue 0.469873 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45776 ms - Host latency: 1.66899 ms (enqueue 0.473486 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46179 ms - Host latency: 1.67683 ms (enqueue 0.499561 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46445 ms - Host latency: 1.67759 ms (enqueue 0.493604 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45872 ms - Host latency: 1.67036 ms (enqueue 0.489014 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4572 ms - Host latency: 1.66514 ms (enqueue 0.470483 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45098 ms - Host latency: 1.66558 ms (enqueue 0.507397 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.55698 ms - Host latency: 1.76982 ms (enqueue 0.480151 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.68042 ms - Host latency: 1.89053 ms (enqueue 0.478198 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45718 ms - Host latency: 1.66716 ms (enqueue 0.471143 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45596 ms - Host latency: 1.66648 ms (enqueue 0.476001 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45593 ms - Host latency: 1.66328 ms (enqueue 0.482397 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45979 ms - Host latency: 1.66958 ms (enqueue 0.472827 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.4551 ms - Host latency: 1.66274 ms (enqueue 0.472119 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45889 ms - Host latency: 1.66904 ms (enqueue 0.469775 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45627 ms - Host latency: 1.66467 ms (enqueue 0.474683 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45603 ms - Host latency: 1.66785 ms (enqueue 0.511938 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45471 ms - Host latency: 1.66287 ms (enqueue 0.47395 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45632 ms - Host latency: 1.66428 ms (enqueue 0.4646 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45886 ms - Host latency: 1.66816 ms (enqueue 0.479492 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45942 ms - Host latency: 1.6708 ms (enqueue 0.465381 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45959 ms - Host latency: 1.6678 ms (enqueue 0.508154 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.46235 ms - Host latency: 1.6728 ms (enqueue 0.47124 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45552 ms - Host latency: 1.66609 ms (enqueue 0.476514 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45388 ms - Host latency: 1.66428 ms (enqueue 0.478101 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45781 ms - Host latency: 1.6667 ms (enqueue 0.484229 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45544 ms - Host latency: 1.6658 ms (enqueue 0.514893 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45823 ms - Host latency: 1.66675 ms (enqueue 0.478516 ms)
[03/27/2024-11:27:23] [I] Average on 10 runs - GPU latency: 1.45745 ms - Host latency: 1.66667 ms (enqueue 0.487988 ms)
[03/27/2024-11:27:23] [I] === Performance summary ===
[03/27/2024-11:27:23] [I] Throughput: 677.972 qps
[03/27/2024-11:27:23] [I] Latency: min = 1.64441 ms, max = 3.78528 ms, mean = 1.68401 ms, median = 1.66721 ms, percentile(90%) = 1.68317 ms, percentile(95%) = 1.69019 ms, percentile(99%) = 2.2627 ms
[03/27/2024-11:27:23] [I] Enqueue Time: min = 0.436035 ms, max = 1.42065 ms, mean = 0.487267 ms, median = 0.479507 ms, percentile(90%) = 0.518921 ms, percentile(95%) = 0.548828 ms, percentile(99%) = 0.657715 ms
[03/27/2024-11:27:23] [I] H2D Latency: min = 0.187988 ms, max = 0.260437 ms, mean = 0.194701 ms, median = 0.193359 ms, percentile(90%) = 0.199707 ms, percentile(95%) = 0.203674 ms, percentile(99%) = 0.215332 ms
[03/27/2024-11:27:23] [I] GPU Compute Time: min = 1.43701 ms, max = 3.57422 ms, mean = 1.47317 ms, median = 1.45654 ms, percentile(90%) = 1.47079 ms, percentile(95%) = 1.47504 ms, percentile(99%) = 2.05078 ms
[03/27/2024-11:27:23] [I] D2H Latency: min = 0.00830078 ms, max = 0.0198975 ms, mean = 0.0161383 ms, median = 0.0167847 ms, percentile(90%) = 0.0185547 ms, percentile(95%) = 0.0187988 ms, percentile(99%) = 0.0193481 ms
[03/27/2024-11:27:23] [I] Total Host Walltime: 3.00307 s
[03/27/2024-11:27:23] [I] Total GPU Compute Time: 2.99937 s
[03/27/2024-11:27:23] [W] * GPU compute time is unstable, with coefficient of variance = 8.41969%.
[03/27/2024-[03/27/2024-11:27:23] [I] Explanations of the performance metrics are printed in the verbose logs.
11:27:23] [W]   If not already in use, locking GPU clock frequency or adding --useSpinWait may improve the stability.
&&&& PASSED TensorRT.trtexec [TensorRT v8502] # /usr/bin/trtexec --loadEngine=example.engine --fp16 --useDLACore=1 --allowGPUFallback
case: idleTime=2000
&&&& RUNNING TensorRT.trtexec [TensorRT v8502] # /usr/bin/trtexec --loadEngine=example.engine --plugins=/usr/src/tensorrt/libplugin.so --fp16 --useDLACore=1 --allowGPUFallback --idleTime=2000
[03/27/2024-11:27:30] [I] === Model Options ===
[03/27/2024-11:27:30] [I] Format: *
[03/27/2024-11:27:30] [I] Model:
[03/27/2024-11:27:30] [I] Output:
[03/27/2024-11:27:30] [I] === Build Options ===
[03/27/2024-11:27:30] [I] Max batch: 1
[03/27/2024-11:27:30] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[03/27/2024-11:27:30] [I] minTiming: 1
[03/27/2024-11:27:30] [I] avgTiming: 8
[03/27/2024-11:27:30] [I] Precision: FP32+FP16
[03/27/2024-11:27:30] [I] LayerPrecisions:
[03/27/2024-11:27:30] [I] Calibration:
[03/27/2024-11:27:30] [I] Refit: Disabled
[03/27/2024-11:27:30] [I] Sparsity: Disabled
[03/27/2024-11:27:30] [I] Safe mode: Disabled
[03/27/2024-11:27:30] [I] DirectIO mode: Disabled
[03/27/2024-11:27:30] [I] Restricted mode: Disabled
[03/27/2024-11:27:30] [I] Build only: Disabled
[03/27/2024-11:27:30] [I] Save engine:
[03/27/2024-11:27:30] [I] Load engine: example.engine
[03/27/2024-11:27:30] [I] Profiling verbosity: 0
[03/27/2024-11:27:30] [I] Tactic sources: Using default tactic sources
[03/27/2024-11:27:30] [I] timingCacheMode: local
[03/27/2024-11:27:30] [I] timingCacheFile:
[03/27/2024-11:27:30] [I] Heuristic: Disabled
[03/27/2024-11:27:30] [I] Preview Features: Use default preview flags.
[03/27/2024-11:27:30] [I] Input(s)s format: fp32:CHW
[03/27/2024-11:27:30] [I] Output(s)s format: fp32:CHW
[03/27/2024-11:27:30] [I] Input build shapes: model
[03/27/2024-11:27:30] [I] Input calibration shapes: model
[03/27/2024-11:27:30] [I] === System Options ===
[03/27/2024-11:27:30] [I] Device: 0
[03/27/2024-11:27:30] [I] DLACore: 1(With GPU fallback)
[03/27/2024-11:27:30] [I] Plugins: /usr/src/tensorrt/libplugin.so
[03/27/2024-11:27:30] [I] === Inference Options ===
[03/27/2024-11:27:30] [I] Batch: 1
[03/27/2024-11:27:30] [I] Input inference shapes: model
[03/27/2024-11:27:30] [I] Iterations: 10
[03/27/2024-11:27:30] [I] Duration: 3s (+ 200ms warm up)
[03/27/2024-11:27:30] [I] Sleep time: 0ms
[03/27/2024-11:27:30] [I] Idle time: 2000ms
[03/27/2024-11:27:30] [I] Streams: 1
[03/27/2024-11:27:30] [I] ExposeDMA: Disabled
[03/27/2024-11:27:30] [I] Data transfers: Enabled
[03/27/2024-11:27:30] [I] Spin-wait: Disabled
[03/27/2024-11:27:30] [I] Multithreading: Disabled
[03/27/2024-11:27:30] [I] CUDA Graph: Disabled
[03/27/2024-11:27:30] [I] Separate profiling: Disabled
[03/27/2024-11:27:30] [I] Time Deserialize: Disabled
[03/27/2024-11:27:30] [I] Time Refit: Disabled
[03/27/2024-11:27:30] [I] NVTX verbosity: 0
[03/27/2024-11:27:30] [I] Persistent Cache Ratio: 0
[03/27/2024-11:27:30] [I] Inputs:
[03/27/2024-11:27:30] [I] === Reporting Options ===
[03/27/2024-11:27:30] [I] Verbose: Disabled
[03/27/2024-11:27:30] [I] Averages: 10 inferences
[03/27/2024-11:27:30] [I] Percentiles: 90,95,99
[03/27/2024-11:27:30] [I] Dump refittable layers:Disabled
[03/27/2024-11:27:30] [I] Dump output: Disabled
[03/27/2024-11:27:30] [I] Profile: Disabled
[03/27/2024-11:27:30] [I] Export timing to JSON file:
[03/27/2024-11:27:30] [I] Export output to JSON file:
[03/27/2024-11:27:30] [I] Export profile to JSON file:
[03/27/2024-11:27:30] [I] === Device Information ===
[03/27/2024-11:27:30] [I] Selected Device: Orin
[03/27/2024-11:27:30] [I] Compute Capability: 8.7
[03/27/2024-11:27:30] [I] SMs: 16
[03/27/2024-11:27:30] [I] Compute Clock Rate: 1.3 GHz
[03/27/2024-11:27:30] [I] Device Global Memory: 62800 MiB
[03/27/2024-11:27:30] [I] Shared Memory per SM: 164 KiB
[03/27/2024-11:27:30] [I] Memory Bus Width: 256 bits (ECC disabled)
[03/27/2024-11:27:30] [I] Memory Clock Rate: 1.3 GHz
[03/27/2024-11:27:30] [I] TensorRT version: 8.5.2
[03/27/2024-11:27:30] [I] Loading supplied plugin library: /usr/src/tensorrt/libplugin.so
[03/27/2024-11:27:31] [I] Engine loaded in 0.00143199 sec.
[03/27/2024-11:27:31] [I] [TRT] Loaded engine size: 1 MiB
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +954, GPU +908, now: CPU 1424, GPU 19043 (MiB)
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +130, GPU +114, now: CPU 1554, GPU 19157 (MiB)
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +1, GPU +0, now: CPU 1, GPU 0 (MiB)
[03/27/2024-11:27:32] [I] Engine deserialized in 1.60375 sec.
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1554, GPU 19157 (MiB)
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 1554, GPU 19157 (MiB)
[03/27/2024-11:27:32] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +2, now: CPU 1, GPU 2 (MiB)
[03/27/2024-11:27:32] [I] Setting persistentCacheLimit to 0 bytes.
[03/27/2024-11:27:32] [I] Using random values for input input.1
[03/27/2024-11:27:32] [I] Created input binding for input.1 with dimensions 1x540x960x3
[03/27/2024-11:27:32] [I] Using random values for output weather
[03/27/2024-11:27:32] [I] Created output binding for weather with dimensions 1x5
[03/27/2024-11:27:32] [I] Using random values for output light
[03/27/2024-11:27:32] [I] Created output binding for light with dimensions 1x3
[03/27/2024-11:27:32] [I] Using random values for output scene
[03/27/2024-11:27:32] [I] Created output binding for scene with dimensions 1x3
[03/27/2024-11:27:32] [I] Using random values for output road
[03/27/2024-11:27:32] [I] Created output binding for road with dimensions 1x5
[03/27/2024-11:27:32] [I] Starting inference
[03/27/2024-11:27:51] [I] Warmup completed 101 queries over 200 ms
[03/27/2024-11:27:51] [I] Timing trace has 10 queries over 16.1657 s
[03/27/2024-11:27:51] [I] === Trace details ===
[03/27/2024-11:27:51] [I] Trace averages of 10 runs:
[03/27/2024-11:27:51] [I] Average on 10 runs - GPU latency: 16.8283 ms - Host latency: 17.0586 ms (enqueue 16.0207 ms)
[03/27/2024-11:27:51] [I] === Performance summary ===
[03/27/2024-11:27:51] [I] Throughput: 0.618592 qps
[03/27/2024-11:27:51] [I] Latency: min = 1.62723 ms, max = 32.5337 ms, mean = 17.0586 ms, median = 14.0352 ms, percentile(90%) = 32.4321 ms, percentile(95%) = 32.5337 ms, percentile(99%) = 32.5337 ms
[03/27/2024-11:27:51] [I] Enqueue Time: min = 0.465164 ms, max = 31.6631 ms, mean = 16.0207 ms, median = 12.8262 ms, percentile(90%) = 31.5857 ms, percentile(95%) = 31.6631 ms, percentile(99%) = 31.6631 ms
[03/27/2024-11:27:51] [I] H2D Latency: min = 0.192154 ms, max = 0.236328 ms, mean = 0.220796 ms, median = 0.226562 ms, percentile(90%) = 0.228027 ms, percentile(95%) = 0.236328 ms, percentile(99%) = 0.236328 ms
[03/27/2024-11:27:51] [I] GPU Compute Time: min = 1.42679 ms, max = 32.2993 ms, mean = 16.8283 ms, median = 13.7993 ms, percentile(90%) = 32.1978 ms, percentile(95%) = 32.2993 ms, percentile(99%) = 32.2993 ms
[03/27/2024-11:27:51] [I] D2H Latency: min = 0.00828552 ms, max = 0.0159912 ms, mean = 0.00955658 ms, median = 0.00878906 ms, percentile(90%) = 0.00976562 ms, percentile(95%) = 0.0159912 ms, percentile(99%) = 0.0159912 ms
[03/27/2024-11:27:51] [I] Total Host Walltime: 16.1657 s
[03/27/2024-11:27:51] [I] Total GPU Compute Time: 0.168283 s
[03/27/2024-11:27:51] [W] * Throughput may be bound by Enqueue Time rather than GPU Compute and the GPU may be under-utilized.
[03/27/2024-11:27:51] [W]   If not already in use, --useCudaGraph (utilize CUDA graphs where possible) may increase the throughput.
[03/27/2024-11:27:51] [W] * GPU compute time is unstable, with coefficient of variance = 65.855%.
[03/27/2024-11:27:51] [W]   If not already in use, locking GPU clock frequency or adding --useSpinWait may improve the stability.
[03/27/2024-11:27:51] [I] Explanations of the performance metrics are printed in the verbose logs.
&&&& PASSED TensorRT.trtexec [TensorRT v8502] # /usr/bin/trtexec --loadEngine=example.engine --plugins=/usr/src/tensorrt/libplugin.so --fp16 --useDLACore=1 --allowGPUFallback --idleTime=2000
Sorry for the late update.
Please find the source code below:
The sleep (idleTime) is called before the synchronization.
So it will longer the DLA submission time.
