DLA , faster rcnn model error
Hi, I have installed it successfully.
Ubuntu 18.04 LTS aarch64
CUDA 10.0.326
cuDNN 7.5.0.66
TensorRT 5.1.6.1
Xavier
I run my caffe faster-rcnn model on DLA with TensorRT 5.1. I have set gpu fallback. I have set FP16.But the error occurs, how do I fix it?
[W] [TRT] Default DLA is enabled but layer proposal is not running on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer cls_prob is not running on DLA, falling back to GPU.
[W] [TRT] DLA Node compilation Failed.
[E] [TRT] Internal error: could not find any implementation for node{conv1, relu1, conv2, relu2, ......, concat, convf, reluf, rpn_conv1}, try increasing the workspace size with IBuilder::setMaxWorkspaceSize()
[E] [TRT] ../builder/tacticOptimizer.cpp(1330) - OutOfMemory Error in computeCosts:0
...Assertion 'engine' failed.
Aborted(core dumped)
I have set batchsize=1, maxworkspacesize=1000<<21, my model is 160*160, but also the same error.
When I was in TensorRT 5.0, this code has the error same as the url below described.
../builder/cudnnBuilder2.cpp (728) - Misc Error in buildSingleLayer: 1 (Unable to process layer.)
https://devtalk.nvidia.com/default/topic/1045093/jetson-agx-xavier/running-tensorflow-models-on-dla/post/5364451/#5364451
It says that this problem will be fixed in TensorRT 5.1, but now error occurs as I descriped above.What causes it? How to fix it? Thanks.
my code
const int useFP = 16;
static int gUseDLACore{0};
void caffeToGIEModel(const std::string& deployFile,
                     const std::string& modelFile,
                     const std::vector<std::string>& outputs,
                     unsigned int maxBatchSize,
                     nvcaffeparser1::IPluginFactory* pluginFactory,
                     IHostMemory **gieModelStream)
    IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition* network = builder->createNetwork();
    ICaffeParser* parser = createCaffeParser();
    parser->setPluginFactory(pluginFactory);
    DataType dataType = DataType::kFLOAT; // default
    if(useFP == 16)
        if(builder->platformHasFastFp16())
            dataType = DataType::kHALF;
        else
            return;
    std::cout << "Begin parsing model..." << std::endl;
    const IBlobNameToTensor* blobNameToTensor = parser->parse((deployFile).c_str(),
            (modelFile).c_str(),
            *network,
            dataType);
    std::cout << "End parsing model..." << std::endl;
    for (auto& s : outputs)
        network->markOutput(*blobNameToTensor->find(s.c_str()));
builder->setMaxBatchSize(maxBatchSize);
    builder->setMaxWorkspaceSize(1000 << 21);
    if(gUseDLACore >= 0)
        samplesCommon::enableDLA(builder, gUseDLACore);
    if(useFP == 16)
        builder->setFp16Mode(true);
    std::cout << "Begin building engine..." << std::endl;
    ICudaEngine* engine = builder->buildCudaEngine(*network);
    assert(engine);
    std::cout << "End building engine..." << std::endl;
network->destroy();
    parser->destroy();
(*gieModelStream) = engine->serialize();
    engine->destroy();
    builder->destroy();
    shutdownProtobufLibrary();
We want to reproduce this issue on our environment.
Could you also share your model with us?
Thank you for your reply.
Could you please tell me a email where I will send the prototxt file?
Although the TensorRT I’m using now is 5, the way I implement plugins is the sample used by tensorrt 4. Like this.
class PluginFactory : public nvinfer1::IPluginFactory, public nvcaffeparser1::IPluginFactory
class Reshape : public IPlugin
Is this likely to lead to my mistakes?
Because I use FP16, so the plugin here
mPluginRPROI = std::unique_ptr<INvPlugin, decltype(nvPluginDeleter)>
                           (createFasterRCNNPlugin(featureStride, preNmsTop, nmsMaxOut, iouThreshold, minBoxSize, spatialScale,
                                                   DimsHW(poolingH, poolingW), Weights{ dataType, anchorsRatios, anchorsRatioCount },
                                                   Weights{ dataType, anchorsScales, anchorsScaleCount }), nvPluginDeleter);
the dataType should be kHALF not kFLOAT, right?
the data which is not weights, such as this, it should be sizeof(float) not sizeof(float)/2, right?
int enqueue(int batchSize, const void*const *inputs, void** outputs, void*, cudaStream_t stream) override
        CHECK(cudaMemcpyAsync(outputs[0], inputs[0], mCopySize * batchSize * sizeof(float), cudaMemcpyDeviceToDevice, stream));
        return 0;
I ran another very similar model to this one . It works. The info is as follows.
[W] [TRT] Default DLA is enabled but layer rpn_cls_score_reshape is not running on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer rpn_cls_prob is not running on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer rpn_cls_prob_reshape is not running on DLA, falling back to GPU.
[W] [TRT] DLA LAYER: Batch size(combined volume except for CHW dimensions) 300 for layer fc6_L exceeds max batch size allowed of 32.
[W] [TRT] Default DLA is enabled but layer fc6_L is not running on DLA, falling back to GPU.
[W] [TRT] Internal DLA error for layer upsample. Switching to GPU fallback.
[W] [TRT] Warning: no implementation of rpn_cls_score_reshape obeys the requested constraints, using a higher precision type
[W] [TRT] Warning: no implementation of rpn_cls_prob_reshape obeys the requested constraints, using a higher precision type
[W] [TRT] Warning: no implementation of proposal obeys the requested constraints, using a higher precision type
Success!
Coincidentally, this three layer rpn_cls_score_reshape, rpn_cls_prob_reshape,proposal are my all plugin layers. For the
warning “Warning: no implementation of…” , is there any releation?
my upsample layer
layer {
  type: "Deconvolution"
  bottom: "inc4e"
  top: "upsample"
  param { lr_mult: 0  decay_mult: 0 }
  convolution_param {
    num_output: 256
    kernel_size: 4  stride: 2  pad: 1
    group: 256
    weight_filler: { type: "bilinear" }
    bias_term: false
It doesn’t work on DLA which is because of kernel_size and pad. But I’m wondering why it doesn’t fall back directly, but prompt ‘Internal DLA error’.
Could you share the difference in model architecture between the fail and success one?
Based on the log shared in #1, the application may crash since out of resource:
Would you mind to monitor the system with tegrastats at the same time and share the log with us?
sudo tegrastats
