DLA Model Quantization Issue: Reformatting CopyNode Fallback Error on Orin
Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linu
Hardware Platform
SDK Manager Version
other
Host Machine Version
Issue Description
I am working on INT8 quantization for a DLA model on the Orin platform and encountered some issues. Could you please help analyze the possible causes?
Case 1: Input = kDLA_HWC4, Output = kDLA_LINEAR
  • The output tensor is already aligned to 64 bytes.
  • During quantization, the following error is reported:
Default DLA is enabled but layer Reformatting CopyNode for Output Tensor 1 to ... is not supported on DLA and falling back to GPU is not enabled.
  • if I randomly remove a few output tensors from the model, the quantization can succeed without the above error.
  • Question: What could be the reason that removing some outputs bypasses the error?
Case 2: Input = kDLA_HWC4, Output = kCHW32
  • In this case, quantization usually succeeds even without removing any outputs.
  • However, there is still a probability of failure, reporting the same Reformatting CopyNode error.
  • Question: Could this intermittent behavior be due to caching issues in the quantization environment, or possibly interference from other users running quantization/inference tasks at the same time?
Error String**
Default DLA is enabled but layer Reformatting CopyNode for Output Tensor 1 to … is not supported on DLA and falling back to GPU is not enabled.
Logs
Dear @qiuwen ,
Could you use verbose flag for more insights ?
Is it possible to share model and repro steps?
