Dlopen error: /opt/nvidia/vpi1/lib64/libnvvpi.so.1: undefined symbol: NvMediaLDCUpdateTNR2Params
• Hardware Platform (Jetson / GPU) Jetson Nano 4GB arm64
• DeepStream Version Deepstream-6.0_6.0.0-1
• JetPack Version (valid for Jetson only) Jetpack version-4.6-b199
• TensorRT Version 8.2.1.8-1+cuda10.2
Tried running nvanalytics apps on nano but tracker error occurs .
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
dlopen error: /opt/nvidia/vpi1/lib64/libnvvpi.so.1: undefined symbol: NvMediaLDCUpdateTNR2Params
gstnvtracker: Failed to initilaize low level lib.
Please follow this:
https://docs.nvidia.com/metropolis/deepstream/6.0/dev-guide/text/DS_Quickstart.html#jetson-setup
Install latest NVIDIA BSP packages
Thanks @Amycao for quick reply. Can u explain what’s the use of BSP packages in jetson devices? because in local machines it’s very straight forward .
It includes kernel, bootloader, drivers, flashing utility, sample filesystem, and more for the Jetson platform.
Thanks @Amycao for this info .
Steps to resolve this tracker issue:
  1. first check whether your jetpack and tensorrt installed properly or not .
  2. Fix those issues
  3. Then try to install DS-6.0 from scratch .
